2 door manual Sport with Rubi suspension and 33s
At Risk Ute
JL
Finally made it out to Colorado to go off roading with friends. Stock 3.45 rear is too tall for both the interstate (turning 2000 rpm at 90 mph) and trails (4L in second was the sweet spot and I was still going too fast with the Rubis in front of me in the pic).
I’m not going any bigger as this is my daily driver grocery getter. Debating a 3.73 or 4.10 rear. Wonder what each would turn in 6th gear going 80 mph.
ChattVol
Tennessee
JLU 4 door
Going from 3.45 to 3.73 gearing would barely be noticeable and a waste of $ IMHO. You should go test drive a stock rubicon with 6 speed to test the 4.10s. Many people feel like the stock rubicon is is a bit underpowered with the 6 speed....80mph is right around 2400rpm.
Below is a helpful gearing calculator that seems to be fairly accurate. If you care about crawl ratio and gas mileage running 33s with your 2.7:1 transfer case, I would go 4.56 gears bc the pentastar likes to run a little higher rpm.
https://www.jlwranglerforums.com/forum/threads/gearing-calculator.38206/
ThirtyOne
Rock Sponsor (Level 1)
Chapel Hill, NC
www.jeepdoodles.com
Part of that crawling in low gear from your Rubicon buddies is the 4:1 transfer case.
ChattVol
Tennessee
JLU 4 door
Yep...the rubicon crawl ratio is 84 and that's why I would go 4.56 gears to put the non rubi crawl ratio at 64...
At Risk Ute
At Risk Ute
JL
  • Thread starter
  • Thread Starter
  • #5
Thank you all for steering me away from 3.73s!
4.10 or 4.56 it will be.
Stinger Off-Road
