2 Door JL Red 3.5" 37's
alice the cat
Robert
San Diego
99 TJ, 2000 Dodge Viper, 2018 tacoma, 2019 tacoma, 2018 BMW 430i gc
I love this build! I wish there were more 2 doors on here, big fan.
aven2rus
aven2rus
Tom
Lake ariel
2018 2 door
Completed the Flares to rid the of the tire rub at full articulation. Straight forward instructions with exception to light install. I had them color match for $400.
Some tips.
Install the light in the fender first thing, can't be done after install and not mentioned.
You can use the insert tool they send it will work fine as the inserts are aluminum. I wasted 2 inserts getting my insert tool depth set as the additional power tore the treads out. Had to use a couple steel insert to complete.
Blow out the inserts and follow up running a bolt all the way through every insert to make sure it is tight and clear of snags. Then follow up with a tab of never seize.
Have friend available to hold the flare tight against the body while you but the final screws in to assure a tight fit.
Fit is great and they mount very solid.
aven2rus
aven2rus
Tom
Lake ariel
2018 2 door
In hind sight I would had snapped a plastic plug in the flare blinker hole and wired to a CJ style light in the grill.
May go back one day and do this.
