Sweetwater
I finally found out how to find your Wrangler date off assembly line. Sticker is on driver's door.
Mine was completed April 13 th. at 7:00 PM. At dealer May 26 th.
My----MDH 041319
Vehicle Certification Label
A vehicle safety certification label is attached to every Chrysler Corporation vehicle. The label certifies that the vehicle conforms to all applicable Federal Motor Vehicle Safety Standards. The label is located on the driver-side door shutface.
On the example above, "Date of MFR" is listed as "1-96" which is "January 1996". At the bottom left of the plate the Month, Day and Hour of manufacturer is listed as "MDH 010615", this means that the vehicle was built January ("01"), 6th ("06") at 3:00PM ("15").
The label also lists:
My----MDH 041319
- Month and year of vehicle manufacture.
- Gross Vehicle Weight Rating (GVWR). The gross front and rear axle weight ratings (GAWR's) are based on a minimum rim size and maximum cold tire inflation pressure.
- Vehicle Identification Number (VIN)
- Type of vehicle
- Type of rear wheels
- Bar code
- Month, Day and Hour (MDH) of final assembly
- Paint and Trim codes
- Country of origin
