2.5 inch RC spring and shock lift kit
  1. Stlrfan152
    Stlrfan152 Active Member
    First Name:
    Jay
    Vehicle(s):
    2018 JLU, 1998 TJ, 1975 Corvette
    Mar 9, 2019
    Western Massachusetts
    27
    Liked:
    Has anyone installed the Rough Country 2.5 inch lift with coils and shocks? Its 399 which doesnt seem like a bad price. Just curious how different from stock it drives?
  2. TTEChris
    TTEChris Well-Known Member
    First Name:
    Vehicle(s):
    2018 JLU Rubicon & Sport(Wife)
    May 17, 2017
    Houston, TX
    2,036
    Liked:
    4,468
    Garage Profiles:
    The RC springs are comparable to the factory springs rates from my understanding. On my Wife's Sport we have tried several different springs with the Rough Country being the softest of the bunch. The only time I have found they don't do so well is when adding a lot of extra weight to the Jeep. They tend to sag a little more than a spring with a stiffer rate.
    OffRoadWarehouse likes this.
  3. IronScott
    IronScott Well-Known Member
    First Name:
    Vehicle(s):
    Sep 21, 2018
    NW Arkansas
    859
    Liked:
    1,019
    I have it on my Sahara. It's a bit stiffer than stock but I'm running E-rated KM3 mud tires so that factors in. I've aired them down to 30 psi and the ride is pretty good now. The RC kit looks good and takes out the front rake. This is my first Jeep and I figured for the price it was worth trying to get my feet wet. I haven't had it on trails yet so can't comment on that but I'm pretty happy with it.
  4. p3rs1st
    p3rs1st Member
    First Name:
    Vehicle(s):
    2019 JLU MOAB Sting Grey
    Mar 8, 2019
    Quad Cities, Iowa
    Liked:
    Garage Profiles:
    how does the RC 2.5 kit ($399) with springs compared to the cheaper RC 2.5 kit with just spacers($199) and utilizing stock MOAB springs? I'm just looking for that extra clearance for when having the 35's on my MOAB. I guess 35's can fit without anything but it's tight and at full lock it will rub. So I'm not wanting to go crazy with a lift.. I think
    From what I gathered from RC's website, the springs just add a bit more ability to stay higher when flexing, since you arent using a spacer, but rather new springs, correct me if I'm wrong
  5. OffRoadWarehouse
    OffRoadWarehouse Well-Known Member
    Rock Sponsor (Level 1)
    First Name:
    Vehicle(s):
    2018 Jeep JL
    May 9, 2018
    San Diego, CA
    154
    Liked:
    115
    Occupation:
    Jeep, Shock, Suspension, and Export Specialist
    Garage Profiles:
    In my experience, Spacers are a great way to get a good static lift height for tire clearance, and looking cool.
    Springs are the better option when you are looking to add more weight to the vehicle, or decide to do a suspension (Long Arm) that requires lots of spring flex.
    Think about it this way, if you are adding nothing on top of the jeep. You will maintain a 2.5" lift with a spacer. As soon as you add bumpers, it is going to add weight that is working against the Factory OEM Spring Rate. This means you could lose a half inch, or a full inch depending on how heavy it is. If you go with aftermarket springs, the length of the coil, along with a possibly higher spring rate can resist that drop better.
    Does this mean that all springs are going to handle extra weight better? No. You will need to look at the reviews on the springs with people that have installed them with a similar setup to yours and make sure its what you need.
    In my personal opinion, Rough Country springs are not going to be worth the increase in cost. I would stick with the spacer for a easy/cheap lift. If I wanted a coil that could handle weight, I'd go Teraflex. For Ride Comfort I would go ICON, Rock Krawler, or some people go Metal Cloak.
    p3rs1st likes this.
  6. p3rs1st
    p3rs1st Member
    First Name:
    Vehicle(s):
    Mar 8, 2019
    Quad Cities, Iowa
    Liked:
    Garage Profiles:
    thank you so much! makes sense
  7. jruss
    jruss Well-Known Member
    First Name:
    Josh
    Vehicle(s):
    2018 Jl Sport Unlimited
    Nov 11, 2018
    Greater Baton Rouge Area
    160
    Liked:
    107
    As a non vendor, everything I have ever dealt with from rough country was trash. That’s on a couple hundred jeeps. They are typically the lowest price and always the lowest quality especially when it comes to suspension and chassis stuff. Save your 399 and put it toward something better, and only spend your hard earned money once. I have seen too many ppl get burned by the price point.
    rohdawg and p3rs1st like this.
Loading...
Share This Page
