2.0T Battery Terminal Nut
Northridge4x4
Summit Sponsor (Level 3)
Silverdale, WA
www.northridge4x4.com
2016 Sahara JKU, 2013 Rubicon JKU
Seller of badassery
Installing a winch or other electric accessories in your 2.0 JL and want to ground to the battery negative terminal?
The 2.0Ts have a bare stud on the negative terminal that would be perfect to connect to, but it doesn't come with a nut. The 3.6s do, but for whatever reason the 2.0T doesn't.
We've got the solution for you!
Announcing the NORJLBATTNUT, it's an M8-1.25 serrated, flanged, hex nut that's zinc coated and screws right down on the stud.
Yes, we are selling a single nut.... one nut. It won't help the loose nut behind the wheel, but it will help you ground electrical accessories!
All joking aside, we just got these nuts in today and they work perfectly... add one to your next order.
If you want to source them locally, we've posted the specs above.
Superchips Flashcal Programmer out for JL Wrangler
