2.0L Water Leak
dav_webb
2020 Rubicon Sarge, 2021 Rubicon 4xe Hydroblue
All I know is that just cranking dow on those two bolts worked for me. I have mechanics hands so two clicks of the elbow is good enough. At this point, problem is solved. It's been a while and I check them about every 3 months and they are still tight.
Whats the trick to getting a wrench on the upper one? I couldn't get a torx on it.
jjvincent
Bethlehem, PA
2021 Wrangler, 2017 VW Alltrack, 2003 VW Eurovan
Mechanical Engineer
I don't know. I have lots of tools (way too many) and since i grew up as a mechanic, I just keep trying.
Buster1
Ft Worth, TX
‘51 M38
Mine are confirmed tight. Just got a socket wrench on them. 5000 mi
LuvHydro
Midwest
21 JLUS Hella , 22 JLUSS Hydro
Mind taking a pic of the tool you used?
Mine isn't included in the TSB but it's very, very close to the, I'm guessing, FCA arbitrary cutoff.
Buster1
Ft Worth, TX
‘51 M38
Nothing cosmic. Regular ratchet, 2” extension, 3/8 drive to 1/4 drive adapter, then the T30 bit.
To get to the lower one, I had to put my head right near the front left tire, on the ground, then reach up over the diff to get the ratchet on the bolt.
Jeep Wrangler JL 2.0L Water Leak CBFAE6C9-F1EB-4617-A138-F061D1FBC11C
LuvHydro
Midwest
Thanks a bunch!!
LuvHydro
Midwest
Jeep Wrangler JL 2.0L Water Leak PXL_20230324_201817163
Doing a little preventative maintenance and figured I would check my bolts. Both were not very tight. I used a t30 bit with the ratchet that comes with the Jeep to get to both bolts from below no problem.
Thanks
syismaster1
Sy
2021 JLU Willys
Jeep Wrangler JL 2.0L Water Leak 722D58F6-13AA-44A9-8E11-26E4C817738F
Jeep Wrangler JL 2.0L Water Leak 81126793-D64D-415F-BDC1-D6F22874FAB9
25000 miles on my 2.0T and no mechanical issues with the engine but I heard my radiator fan screaming so I checked the temp and I’ve never seen it over 222 so I check outside and there’s a massive puddle of coolant. Didn’t expect that out of nowhere. My battery light also came on?
Windshieldfarmer
Randy
Wichita, Ks
2015 JKU, 2020 JlU on order
I’m guess it’s those two water pump torx screws. If so, Chance P has the solution. I suspect you didn’t overheat excessively.
syismaster1
Sy
2021 JLU Willys
Holy crap I did not realize this till I read ur comment but the dealer 'supposedly' fixed this recall when they had the car in January. Apparently it did not work so lets see what they say tomorrow...
jaswifty
jason
pa
2020 Toyota Tacoma Pro
