2.0 Turbo with 35s or 37s PICS
RubiconMarcSF
Marc
San Francisco
I’m getting ready to lift my Rubicon and deciding whether to go with either 35s or possibly 37s.
Post your rig and comment whether you have any issues whatever size you’re running. Thanks!!
cOtter
Southern, Indiana
‘20 Sahara 2.0L Ocean Blue Metallic, Toyota Highlander & Pontiac G6 coupe
Senior Manager PM (Automotive OEM)
‘20 Sahara 2.0. 35’s. With the Mopar lift. It’s my DD. No issues, however it is nearly 100%. On road. It has been on numerous country dirt and gravel roads as well as through multiple fields, but nothing that I would label as off-roading. Just being honest.
Sept 5th was my one year gotcha day and currently have just over 20k miles on it. Setting around 22 mph average.
Good luck.
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
My first setup was the Dynatrac Endurosport true 2" lift with 315/70-17 BFG KO2's. Everything about it was great once dialed in, but it wasn't enough and it couldn't take much cargo weight (a dozen bags of groceries in the far back or 2 average sized adults on the rear bench seats) before sagging a noticeable amount. I'm now at about 4.25" lift from the Metalcloak 3.5" kit and rolling 38's. Again, once dialed in its an absolute dream. A bit stiffer of a ride to stand up to normal everyday loads, without being at all uncomfortable. Here's some direct comparison shots of both stock and with each lift. The only front shot I have of the first setup was taken after I chopped the front fenders. Also of note, the 315 ko2's are one of the smaller "35's", coming in at about 33.75". The 38" Milestar Patagonias are closer to true size at about 37.5". I belive the factory 285's were about 32.25".
ExpeditionBuilds
Rock Sponsor (Level 1)
Steven
Chicago
www.youtube.com
2020 Wrangler Recon
Photographer/ Content Creator
Here's before and after pics of the MetalCloak 3.5" Game Changer lift, 37" Nitto Ridge Grapplers.
Once calibrated (Tazer), the 8 Speed covers the 37's well with the stock 4.10 gears. I'm still hitting 8th gear ~80mph on flat ground. In fact, to my surprise, acceleration and braking are still great. I'm a huge fan of the 2.0L Turbo.
-Steven
OnlyOne
Eagle, Colorado
2019 JLR Bikini Turbo on 37’s /2019 Mustang GT PP1 A10 whipped
37’s
Houston
2020 Wrangler Unlimited High Altitude
35s, but re-geared to 4.56. Great low-end torque and zip ... really unleashes the 2.0T. Run about 2300 RPMs at 75 MPH, fully recalibrated. Will likely move to 37s once the Nitto Ridge Grapplers wear out.
Crawl Away
Jeremy
DFW
2019 Wrangler Rubicon Unlimited - 1998 TJ Sport
2.5” lift and 37” KM3s with stock wheels and 1.5” spacers. Happy with gearing and tire and tire size.
Superchips Flashcal Programmer out for JL Wrangler
