2.0 turbo making very loud noise when you step on the accelerator
SkyHuff25
Sky
Iowa
2018 jeep wrangler JL Sahara
Just bought a new 2018 JLU Sahara and have been loving it. has about 1300 miles on it now and today it started acting weird. i was noticing some very low whistling sounds which is due to the turbo I am sure, but when I punch it to accelerate a very loud screaming/revving sound has started that was not there before. seems to only happen once the turbo kicks in. I have made an appointment with the dealership to find out whats going on but just wanted to see if anyone else has heard of this. cant really find anything online that describes what I am hearing.
morricus
Illinois
2018 Rubicon Unlimited, 2015 GMC Yukon XL, 2006 BMW M3
Wow. Screaming/revving sound. A turbo is nothing more than an air compressor, sucking in a tremendous amount of air that can make a tremendous amount of noise. I'd be willing to bet there is absolutely nothing wrong with your car. Its a turbo acting like a turbo when you spool it up under load. If you haven't thrown any codes (check engine), the chances of it being an issue are remarkably low.
Paluss
maryland
2022 JLURD
isn't that a supercharger? A turbo is driven by the engines exhaust gas
morricus
Illinois
No. Both a supercharger and a turbo compress the incoming air. A supercharger is a compressor that is engine driven with a pulley or belt. A turbo is exhaust driven.
JeepCares
Auburn Hills, MI
JL
Hello SkyHuff25,
Keep us updated on your dealer visit. If we can be of any assistance, please dont hesitate to send us a direct message.
Lamar
Jeep Social Care Specialist
Papi4baby
MD
19 JLUR
Wonder if you blew a air pipe.
Does it sound like air? Also is there a drop in power?
SkyHuff25
Sky
Iowa
Hello SkyHuff25,
Lamar
I have taken it into the dealership and let them hear it. It is almost like the turbo isnā€™t working. They agreed that there is an issue and I have an appointment on Thursday. Will update once I find out whatā€™s going on
SkyHuff25
Sky
Iowa
Yes it does sound like air and the power has went way down. I clocked 0-60 at 12 seconds!
JeepCares
Auburn Hills, MI
JL
Hello SkyHuff25,
Thank you for the heads up.
Lamar
Jeep Social Care Specialist.
Papi4baby
MD
19 JLUR
You can chase the pipes coming from the turbo and see if any have become disconnected if you want.
Fairly simple if you can see them. Whenever they connect to a component they are held by a metal clamp.
If one is, loosen the clamp attach it back and tighten it back up.
SkyHuff25
Sky
Iowa
Hello SkyHuff25,
Lamar
Still in the shop and they donā€™t know why it is making that noise. They said they are waiting on Chrysler to tell them what to do. They told them to compare the sound to a few other jeeps. Really frustrating having bought a $46k Jeep and have it in the shop two weeks later with an issue they donā€™t know how to fix.
JeepCares
Auburn Hills, MI
JL
Hi SkyHuff25,
I just responded to your private message, but wanted to touch base with you here as well to give you a heads up. Please review my message and follow up with me there when you have a chance. Hope to hear from you soon.
CoolTech
Rock Sponsor (Level 1)
Kendall
Santa Clarita, CA
2018 Rubicon
Based on your description (a lot of sound and no power), I would speculate that you have a boost leak. After the turbo compresses the air, it has to travel through a large hose to the intercooler which is at the front of the Jeep, pass through the intercooler, and then back through a large hose to the engine. I would guess that one of these hoses has become compromised or perhaps the intercooler itself has a problem. However, it is a little peculiar that you don't have a check engine light.
A second guess is that the wastegate is stuck in the open position. In normal operation, the Jeep ECU will gradually open the wastegate as it approaches maximum boost. This prevents the turbo form creating too much boost pressure. A compromised wastegate will also produce a peculiar sound and you will have no power as the engine cannot build boost.
SkyHuff25
Sky
Iowa
Dealership said that the valve clamp on the hose going into the back of the turbo was off, they got it taken care of and I am back on the road
JeepJLBase
Earth
Yes
Yes, but the difference is that a supercharger is spooled up and ready to deliver power instantly.
