Uhdinator
The dealer can't install my floor mats correctly........why would I pay them to change my oil?
He's in Canada where it's metric. I think he said he bought a 5-Liter jug of oil not 5 quarts? Never mind, I see everything was cleared up. I should have read the full thread before replying.@Arterius2
Why did you not use the whole 5 qts. of oil? You say you "left about an inch of oil left in it."
Anyway, it s not debatable lets say.. The JL 3.6 and 2.0 both take 5 qts. With that said put in 5 quarts, exactly.... end of story.
After you have the five quarts in, let the JL sit for a couple of hours or so and then read the dipstick. Level indicated on the stick is the 5 qt./full fill level. You might want to take a pic of the dipstick level so you know .... have for future reference.
Yes, the dipsticks on both motors are a pain to read.
By the way... when I do the oil change, I pour in the 5 qt. container and then do not even check the dipstick. Why would I need to check the dipstick. Motor takes 5 and I put in 5. YES, for checks down the road, it is nice to know what 5 qts reads on the dipstick.
I concur. Very tight and easy to smear. My previous JK was wayyyyy easier. Plus this ones deeper into the engine bay.I had the same problem with the dipstick; two-handed is the only way to do things.
I thought the dealer overfilled the first oilchange so I did the next a bit earlier myself. I see the same, 5qts in after a hot extended dran of the crancase and filter. 5qts was about 1/2-3/4" above the top mark. I guess it's normal..Thanks, I posted picture of the dipstick reading (measured 5min after engine off as per user manual)
It seems counter intuitive if 5 quarts (equivalent) measures 3/8" over the upper hole, unless I actually overfilled it, or 5L is actually not 5L as stated on the bottle..
Just want to know what other 2.0 owners are reading on the dipstick with 5 quarts, just for reference sakes for next time...
It might be Just-a-Jeep-thingā¢ where everything needs a "mod" to function like other vehicles at stock.
@QC22Sorry to dig up this thread, but someone linked it on a current one... Anyway, how do any of you know that you or the dealer got all the oil out? Just because the capacity (with filter) is 5 qts does not mean that it takes that much always, every change, period. As someone earlier said. How much remains in oil passages throughout the engine? What if you're not parked level? What if the dipstick is marked wrong? What if you don;t wait long enough to drain completely? There are no guarantees on any of this stuff, so I find it odd that we literally quibble over ounces.
@QC22I actually agree with you sort of. You don't know how much is left in there. Also, in the olden days, some heavy truck engines were shipped with blank dipsticks. Depending on the cab, they might need to be extended, or cut off, and how you did it was fill it one gallon low, mark the stick for the low mark. Pour in another gallon, and that was the full mark. Yes, gallon. If you trust the stick, I would go by that. Over full is worse than slightly under.
This is the key.I give plenty of time for the oil to drain....
Thanks for tagging us. If you decide to bring your Jeep to the attention of a dealership and need our support, send us a private message.Not sure if all this is still a debateā¦ But Iāve been filling mine with 5qts since purchase. Oil level always read above the full line as stated above. At 50k mi, changed my PCV valve all gunked up. At 60k mi, had a leaking valve cover gasket and a bad O2 sensor replaced. And now at 85k mi, gotta go back into the dealer to get a persistent oil leak looked at to determine if itās the oil pan seal or a leaking rear main seal! Every 3-4k miles, Iāve always allowed time for my warm oil to drain completely and put in a full 5qt container of pennzoil. And always seen the oil level read just over the full dot on the stick. Time to see if @JeepCares cares, and see how they regard this potential rear main sealā¦
