Rubi
- David
- Dec 25, 2016
- Connecticut
- ā18 Jeep JLR
I disagree with you on the break-in. When I applied the throttle within the first 500 miles, it was a complete dog. As I stated above I didnāt get optimum performance until I reached 1500 miles. I know what I felt and what I felt was complete sluggishness. This is much easier to quantify with a 6 speed because you have to shift to keep the engine in its powerband. The automatic will shift itself without you knowing it unless you actually pay attention.Engines are essentially broken-in at the factory nowadays. There's a little wear in the first bit of driving, but the hone is already off the cylinder walls by the time you're 100 miles down the road. The ECU just tunes itself based on conditions from fuel to air density, and you get acclimated to the vehicle. The break-in period is more about the transmission/differentials/etc. Either way, if that were true of the 3.6, it'd be true of the 2.0 (or any other engine for that matter). One could argue people aren't testing 'the optimum 2.0' based on your assertion regarding the 3.6.
The only thing that is likely happening re: engine after the initial hundred miles or so is the tune/timing being adjusted to match the petrol you use, and the throttle (not sure if it's dynamic on Jeeps) and transmission (not a function with your 6-speed) adapting to driving habits. I've never seen any engine I've data logged require 500+ miles to adjust to conditions and run optimally. You can run a used oil analysis (I've done this on all of my built engines) on samples taken at intervals during break-in, and see when the wear slows down.
I'll duck out now, I've been a part of polluting OPs thread enough. Congrats again!
The 2.0 has a benefit with its initial 500 miles or so, in that the 4 cylinders are, .1 liters each, smaller resulting in less friction. The drivetrain, connecting rods and crank will all have considerably less friction because of the two less in quantity and overall size compared to the 3.6. Also because the 2.0 only comes with an automatic; this reverts back to what I said above concerning shifting versus the 6 speed manual. One other thing is the turbo would probably help it out somewhat with an initial break-in.
Itās time to compare seat of the pants performance with apples to apples instead of apples to bananas. The only way this can be accurately done is when theyāre both broken in at 2k miles.
