1700 mile oil change
Biscuit
Northeast Ohio
2018 JLU Sport
It is wise to change your oil for the first time within the first 2 to 3 thousand miles.
Why do you care? If it makes them feel good, why not.
Peeing your pants gives you a warm feeling, too, and it doesn't cost anything. :cwl:
Y'all can spend your money on unnecessary oil changes if you wish, but that doesn't make you a wise person.
digitalbliss
North Alabama
2018 JLUR, 1979 CJ7
You are aok at 1700 miles. HEY, go here and get your $10.00 rebate on that 5 quarts of Pennzoil!
http://www.pennzoil.com/en_us/promo...6b2lsLzIwMTZuZXdzbGV0dGVyLz9sb2NhbGU9ZW5fdXM=
Also, read here: https://www.jlwranglerforums.com/fo...m14-1-5-drain-valve-for-the-wrangler-jl.4441/
Be sure to:
Reset your JL's Oil Life Tracker after oil / oil filter changes!
Oil Life Reset Method:
1. Without pushing the brake pedal, push and release the
ENGINE START/STOP button and place the ignition to
the ON/RUN position (do not start the engine).
2. Navigate to Oil Life submenu in Vehicle Info in the
instrument cluster display.
3. Push and hold the OK button until the gauge resets to
100%.
Secondary Method For Oil Change Reset Procedure
2. Fully press the accelerator pedal, slowly, three times
within ten seconds.
3. Without pushing the brake pedal, push and release the
ENGINE START/STOP button once to return the ignition
to the OFF/LOCK position.
NOTE: If the indicator message illuminates when you
start the vehicle, the oil change indicator system did not
reset. If necessary, repeat this procedure.
Thanks for this. The dealer did not reset after my oil change today.
Rhinebeck01
2018 2dr. Rubi
@ all Pennzoil users..
Don't forget to go here and get your $10 rebate (yes, $10) on your $27.00+- 5 qt. container of Pennzoil. Pennzoil is quick to send the check... http://www.pennzoil.com/en_us/promo...6b2lsLzIwMTZuZXdzbGV0dGVyLz9sb2NhbGU9ZW5fdXM=
Yup, you pay about $17 or less in the end for that 5 qts. of Pennzoil.
I bought them on amazon. Made for the JL. If buying, make sure you pay attention to cloth or leather. For some reason it makes a difference here.
https://www.amazon.com/gp/aw/d/B07DC9SMTP?psc=1&ref=yo_pop_mb_pd_title
Just got another rebate check from Pennzoil. Pennzoil get the check right out...
After $10 rebate, it ended up I paid $14.23 for the 5 qt. bottle of Penzoil Platinum..... Add the $6.39 I paid for the OEM oil filter at amazon.com and my 1st oil change cost me $20.62.
No, I do not let dealership service departments do my oil changes, free or not.
heamick
Herb
Whitefish
2018 JL Wrangler JLU Rubicon
Well, I got bored today and decided to do the first oil change at 1700 miles on my JLUR.
Went with Penzoil Platinum 0W20.
After I did the change I started to wonder if I did it too early and maybe the rings aren't set, etc. I'm sure it will be fine, but is there any cause for concern? Thanks!
Not sure I can run 0W20 when its 90 and higher, got to go full sun 10-30
DanW
Indiana
I wouldn't worry. The stats on these 0w20 oils are excellent. They'll do fine. The flash point on Mobil 1 ow20 EP or AP is higher than most 10w30 oils, even synthetic. These engines will live long on quality 0w20 oils. If you are worried, then just change them at 5 or 6 thousand miles. I'd do that before I'd go to a 10w30. My last two oil analyses showed the factory fill and Mobil 1 EP 0w20 to be in good shape after 2k and about 3k miles, respectively.
mgroeger
Hurricane, UT
2018 JLU Saharicon "Mud Muffin" (Wife), 2018 JLUR "Fat Ninja" (Me)
Mt service manager said I could easily go to 5w-20 and we get plenty of heat here in NC. I'd be a little leery of 10w-30 unless I had some serious miles on the Jeep and it was plenty hot out and it was full synthetic. Pennzoil is what goes in them from the factory and that's what I have been sticking with.
DanW
Indiana
I think your dealer is right. When hot, it is still in the 20 weight range, which is within spec. You can't go wrong with that plan. Just remember, though, that 0w20 is also within the same range when hot. It is only a zero weight when cold.
Mac Haik CDJR Georgetown
