15 inch rims on JL Sport
Kluk Ztopolovky
Kluk
Toronto
Wrangler JL Sport 2dr Sting Gray manual
Right now I do not aim for extra lift but I surely woul'd like to install beefier tires on the Jeep . Is there a way I could fit 15 inch rims with this tire in my JL? One has to consider the studs on JL are now different size too.
1/2 in. x 20 (07-18 Jeep Wrangler JK)
14mm x 1.50 (18-19 Jeep Wrangler JL)
Trail Country EXP
All Terrain
Stuckinthesand
CJ
NJ
2019 Wrangler Sport S
15’s won’t clear. If I remember correctly you can’t even put on the 16’s. Don’t quote me on the 16’s but I am positive on the 15’s.
blnewt
New Mexico
Just ask @cosine he knows!
There was a member here that ran 16s, can't recall his name though. They were a chrome wheel w/ the large holes FWIW.
Pig-Pen
Eastvale, CA
2018 JLU
jabroni
Trail Country EXP
All Terrain
thats just the studs, the lug pattern is the same so if it fits a JK it will fit a JL/JT (except diameter)
Pig-Pen
Eastvale, CA
2018 JLU
jabroni
i think Sean? he's an active poster here. he's probably the only person on 16s lol. definitely a cool idea and probably cheaper for tires too.
Arterius2
Jerry
Vancouver, BC
2018 JLU Sahara 2.0L
Kluk Ztopolovky
Kluk Ztopolovky
Kluk
Toronto
from what I've read 16s will fit, the studs are 14mm on JL and 1/2 on JK but then again the JL stock lug nuts may not properly sink into the R16 stud hole
blnewt
New Mexico
Kluk,
With the larger JL rotors and associated calipers there may be some 16s that will work and some that have a thicker barrel or too much backspacing that may have clearance issues. If you end up doing this I'd go with a wheel that you could test fit vs. buying a set online and then be on your dime to ship them back if they're a fail.
