100% Battery Range
BluJay
JT
Wichita, KS
2021 Jeep Wrangler Unlimited 4xe Sahara
Hey all,
I have been pleasantly surprised with the amount of range I've had in EV mode. I've had total range estimates that far exceed the EPA 21 Mile estimate. I've seen 25, 28, 30, and this morning I saw 32 miles at 100% charge. Pretty incredible! Does anybody know if it calculates range based on your driving habits or is that not taken into account?
Sboden
Kansas City
2021 JLUR 4Xe, 2.5" lift, 17" wheels, 37" tires
Another poster said it is based upon driving habits when I posted a higher than EPA mile amount.
SnB4xe
Greg
Mesa AZ
Wrangler High Altitude 4xe
It appears to calculate range by battery state of charge x recent mi/kWh figure for your driving style/speed etc.
This method is very common in the industry and seems to be the most reasonable method. A fully charged battery in the 4xe is about the same as a half gallon of gasoline. (0.43 gallons to be exact...) If you look at it that way......then your Jeep is getting over 60 miles per gallon of energy under those driving conditions. Pretty nice. :)
However, as electrified vehicles become more normal.....we are going to stop talking about miles/gallon equivalent (MPGe) and migrate to a mi/kWh figure instead. You are getting about 2 miles/kWh. My Focus Electric averages 4.0. My Mach-E averages about 3.5. When the BEV Wrangler becomes available for sale we might be lucky to see 3.0 mi/kWh. (this last sentence is just a guess though......)
BigGreen
Al
Arizona
JL Sport
The wrangler is going to have a massive difference between city/Highway range due to aerodynamics. EPA measures a mix, and if you’re all city/sub 45mph, you’ll easily beat EPA estimates. Winter will give you depressing range estimates.
SnB4xe
Greg
Mesa AZ
Unless you have heated seats then it isn't that big of a penalty. Depending on how cold it gets of course. Here in AZ, heated seats used in tandem with departure time pre-conditioning goes a long way to minimizing range loss during winter driving.
Does the 4xe have a PTC resistive type heater? And can it be turned off?
BigGreen
Al
Arizona
JL Sport
Even here I was getting a 40% reduction in range during the winter with my 500e
Little Switzerland, NC
2018 Subaru Crosstrek, 2021 JLURe (coming soon)
How do heated seats increase the range?
SnB4xe
Greg
Mesa AZ
Does the Fiat have a way to disable the e-heat?
In my Focus Electric....I had to program my own "My View" for the left side of my instrument display to show kW usage for climate controls. That was the only way for me to know if the e-heater was active. I then would have to mess with the temperature controls until the energy gauge fell back down to zero or nearly so. In my Mach-E, I can actually turn off e-heat so it won't come on even if I have the temp setting higher than ambient (provided I am not in Auto mode...)
Not really concerned about the 4xe right now.....but when fall comes around then I'll be hunting for a way to disable e-heat. Hopefully there is a setting for that. :)
SnB4xe
Greg
Mesa AZ
Heated seats avoid range loss when using the electric heater.
During cooler months, if your EV is plugged in then you can usually set a departure time and temperature setting so the vehicle will pre-condition the cabin for you. So, it could be 32 degrees outside but a nice and toasty 72 degrees in your car. Ice and snow already melted and you are ready to hit the road. Since it's already warm inside the cabin, then you can turn on the heated seats and steering wheel and not use the climate control to heat the cabin. This is very effective, especially if you are the only one in the vehicle.
So, it doesn't increase range......just avoids using it on the cabin heater. A very useful trick for electric vehicle owners to be aware of. If given the choice when buying one of these vehicles.....get the heated seats and steering wheel. :like:
BigGreen
Al
Arizona
JL Sport
I’m not sure what e-heat is, I know the climate controls were not running. The battery did have temperature management for both heating and cooling. Obviously, it takes more energy to heat than to cool the battery pack.
SnB4xe
Greg
Mesa AZ
So, it doesn't increase range......just avoids using it on the cabin heater. A very useful trick for electric vehicle owners to be aware of. If given the choice when buying on of these vehicles.....get the heated seats and steering wheel. :like:
Of course my comments only apply if the 4xe has a PTC heater. I presume it does....almost all plug-in vehicle do. (some have heat pumps....). If the Jeep 4xe DOESN'T have an electric heater then it must rely on the engine to make heat.....which would kinda suck if that was the case. I will research and see what I can find out.....
BigGreen
Al
Arizona
JL Sport
Wouldn’t that be a more efficient setup? The engine would both charge the battery and heat the cabin on cold days. Vs draining substantial energy from the battery pack to heat the cabin.
SnB4xe
Greg
Mesa AZ
Interesting. I know very little about the 500e systems. I wonder how it makes heat?
"e-heat" is the industry term for a Positive Thermal Coefficient (PTC) heater. Basically a fancy name for a giant electric heating element. They draw a bunch of watts and as you already learned....can impact range in a battery electric vehicle.
Many if not all PHEV (Plug In Hybrid Electric Vehicles) have a PTC for cabin heat when the ICE is not in use. I presume the 4xe has a PTC but I don't know that for certain. I will have to do some research....
SnB4xe
Greg
Mesa AZ
Not more efficient....but less expensive for sure. The problem there is that we would be required to run the ICE to heat the battery pack when necessary. Not ideal.
Now that I think about it.....the 4xe must have a PTC because it is able to heat the battery when parked on plug.
Quadratec
