RebelOffRoad
- Evan
- Jul 28, 2016
- Website
- www.rebeloffroad.com
- 2018 Jeep Wrangler JLU / Jeep Wrangler Rubicon 392
- Occupation
- Jeep Builder
Get 10% off all Recon Coilover Kits! Discount applied at the checkout screen.
View Recon Kits: https://rebeloffroad.com/rebel-recon-kit/
Get 10% off Rebel Halo Racks!
Developed in-house, the HALO has been tested on the Rubicon, MOAB, Hammers, and every trail in between. Because there are no support bars, vehicle side clearance while navigating obstacles is not sacrificed. The steel grating is welded to the HALO outer ring with 2 cross-support bars for rigidity and strength. HALO is rated to 500 pounds - Jeep Wrangler Unlimited Hardtop maximum carrying capacity is estimated at 250 lbs cargo.
View Halo Racks Here: https://rebeloffroad.com/rebel-halo-racks/
Get 10% off Jeep Wrangler JL Bak-Pax
For those with a relocated spare tire, this is the perfect thing to take its spot! Compatible with Rotopax storage cells, easily access your spare fuel, water or first aid kit from the rear of your Jeep JK or JL. With a pre-drilled top mounted accessory rail, attach up to 4 communications antennas or rear facing lights. Also comes with removable license plate mounting bracket. Made In The USA!
View Bak-Pax Here: https://rebeloffroad.com/bak-pax-for-jeep-jl-wrangler-from-rebel-off-road/
Now available, from Rebel Off Road, the Multi-Purpose Mount for Jeep Wrangler JK and JL. This stainless steel mount attaches to your factory/aftermarket tailgate hinge and gives you the ability to run a CB radio antenna or dust light. Made in the USA!
Features:
· Location for mounting a CB radio antenna or a chase/dust/reverse light
· Stainless Steel construction
· Made In The USA
· Works with both JK and JL factory hinges
· Built-in bottle opener for quick cap disconnects
· Available in a stainless steel or powder coat finish
· Includes standoff spacers so you wont scratch the hinge paint
View Multi-Purpose Mount Here: https://rebeloffroad.com/rebel-off-road-multi-purpose-mount/
Rebel will be closed today but will reopen on Tuesday at 9 am. All email orders will be accepted.
IF YOU HAVE ANY QUESTIONS PLEASE GIVE US A CALL AT 866-900-8841
OR BY EMAIL [email protected] TO SPEAK WITH A BUILD SPECIALIST.
