Chris Hall
- Chris
- Oct 19, 2020
- Clayton, Ohio
- Smart Electric Drive, Wrangler 4XE coming soon.
Today marks one month with my Wrangler 4XE. Still amazed and still impressed with the design decisions. It’s just a great overall vehicle. I have developed just a short wish-list. These are not complaints as much as just things I wish were possible.
1-Latching max regen. I would also like to see the max regen button moved to the steering wheel and give a button that could either be momentary or latching. The idea is a button that could be pushed for momentary then pushed and slid to a locked position for latching
2-Eco mode for the cruise control when in EV mode. I have found the cruise control is aggressive enough to cause an engine start. If I’m on back roads and come to a stop sign then hit resume after stopping, the vehicle wants to get back to speed fast enough to cause an engine start.
3-Engine start in EV mode only when the accelerator pedal is floored. I would like to see a way to set the bias in electric mode even more toward electric so that the engine would not start until the pedal goes all the way to the floor. Mercedes utilized a “drop down” button under the gas pedal. It causes the transmission to drop down a gear. Smarts do the same thing. It would be cool to see an “engine start” button under the accelerator pedal to prevent the engine from starting unless that button is pressed.
4-Some method of measuring electrical energy. On the trip odometer and the overall MPG screens, I’d like to see something to indicate miles per kilowatt hour. It would also be nice to see some method to track energy consumed during charging.
5-Larger glove compartment.
6-Slightly larger battery. I’d like to see around 35-45 miles of electric range.
7-Uconnect is horribly slow. I know this isn’t necessarily a 4XE thing but the Uconnect is just way slower than I think most consumers would expect in 2021. That seems like a point that should get some major work done on it. As it is right now, I have no plans to continue with the service once the free period runs out due to this issue.
8-The randomly appearing backup parking lines. This issue isn’t unique to the 4XE but it’s something Jeep should really get fixed.
