Poynter32
- Aug 26, 2017
- Sarasota, FL
- 2018 JL Rubicon Granite Crystal
Hey guys and gals. For those of you that are going to install the pro comp 2” spacer lift (and I’m guessing the rubicon expresses 2”) just thought I would share some tips. I’m not the most mechanicly inclined but I know a few things and this install wasnt that difficult. On the front end If you are by yourself I would only remove one side of the sway bar frame mounts at a time to install the spacers then move to the other side. I didn’t remove the driveshaft as the new instructions say. I was working off old ones and didn’t need have that step until later. So removing that is unnecessary. Make sure to remove the brake line from the frame mount as well as the control arms. Also remove the axle actuator plug and the clips holding the wire in place. This will allow you to lower the axle further to get the springs out. The front bumpstops are a pain to ge the bolt tightened. Unfortunately I don’t really have any tricks. On the rear the only difficult part is getting the threaded washer above the frame, for the rear spacer, tight enough to not spin. As you can see from the post above I had to work the bolt in and out a few times frist the clean the paint out of the threads. For bowman I have not drilled a new hole for the rear sway bar links. I’m not sure the rubicon express lift even mentions this so I’m not sure it’s is necessary. I may do it later but not sure. I hope this helps and if you have any questions feel free to ask.
