Sold: Iowa 0.75-1.5" lift recommendation
LizardBoy
LizardBoy
Iowa, US
Wrangler Unlimited Sahara 2019 2.0L
Thank you, everyone. Sorry about posting in the wrong place!
LemonsOnly
Nate
North TX
2021 Jeep Wrangler Unlimited Willys
If you’ve got a Sahara, your best and most economical route is to go with a take off rubicon suspension in my opinion. It would give you the 1-1.5” you’re looking for and a low mileage set of springs/shocks can be found for $100-150 usually. It would also be a true spring lift vs a spacer lift. Not that I’m against spacer lifts. I run a 2.5” spacer lift on my Willy’s and it works for me.
Do you have pics of your Willys with the spacer lift? Did you keep the springs stock? I keep going back and fourth if its that beneficial to add the Rubi take off springs. Doing a 2in spacer lift on my Willys, 2in up front and 1.5+.5 puck in the rear since my Willys sits almost level stock.
Odyssey USA
Daniel
Indiana
www.youtube.com
Sahara
What are you doing about shocks? Extension brackets? New shocks?
LemonsOnly
Nate
North TX
Just plan on keeping the stock Rubicon shocks that comes on the Willys for now. I did order the slightly longer mopar front control arms.
The goal is to just gain some clearance while keeping the Jeep fairly stock. I think slightly lifted would look better as well. Not ready to do full blown lift with shocks and everything until I figure out what my true needs will be.
