🔋🔧 MAIN BATTERY REPLACEMENT TALK - JL/JT 🪫
blnewt
New Mexico
Just ask @cosine he knows!
Multiple places..
@Rhinebeck01 thanks again for another great and useful/helpful thread!
This battery seems like a good buy and has some solid specs, what do you think about this one, gets decent reviews on the Amazon site
https://www.amazon.com/ACDelco-94RAGM-Professional-Automotive-Battery/dp/B006N91C2M/
I'm not familiar with that one. Do check spec/measurements to assure physical size is aok. Compare to physical measurements of H7's in the list.
IF you use and it fits, do post back so I can add to the list.
garyji
Gary
Western NC
Thanks again Rhinebeck. Wonder if the mods could perhaps sticky this thread?
G.
blnewt
New Mexico
DDESLAU
Doug
Chicago
Wrangler
Thanks for the great info, appreciate it all being consolidated in a single thread. Had a question regarding the H7/94R battery. When I went to order it indicates that it is NOT for use with ESS. Anyone know if it is indeed okay to use the 94R battery with the ESS?
Jeep Wrangler JL 🔋🔧  MAIN BATTERY REPLACEMENT TALK  - JL/JT 🪫 1663770593900
Multiple places..
@DDESLAU
Disregard that ...
For the Main battery, it does not matter .... Just buy an H7 that is known to fit.... all on the list earlier in this thread will fit.
OldBlue
Doug
Chatham Twp, OH
See my Signature
Aerospace Forgings Test Lab
Thanks @Rhinebeck01. Lots of good info here. The wife's JLU has got almost 3 years on it now, so this info will come in handy sooner rather than later. Hers does not have the tow package, but I'll still replace hers w/ a 94R/H7 after removing that plastic piece.
--EDIT--
Her JLU is now 37 months old. Aux battery is bypassed, but I'm seriously considering replacing the main battery now prior to the cold weather settling in on NE Ohio. May take another look at the battery @blnewt posted earlier.
BadA$$Rubi
Bryan
Northeast Ohio
2019 JLU Rubicon
Main battery replacement on a stock JL/JT....
A JL or JT with tow package leaves the factory with an H7-AGM Group Size 94R Main battery.
A JL or JT without the tow package leaves the factory with a Group 48 H6 Main battery, which is a tad shorter in length then the H7-AGM Group Size 94R.
With that said, if you go to install an H7-AGM Group Size 94R battery in a JL or JT that left the factory with a Group 48 H6 battery you will, in order to install the H7, have to remove a small plastic stay/cleat you will find in the bottom of the Main's battery holder box. The stay/cleat comes out very easily.
For those replacing your JL or JT's Main battery... you are best served going with a higher CCA H7 versus installing a lesser CCA H6. Should also mention that often you will find the H7 costs the same as an H6.
Note: When buying an H7 is is prudent to first remove your current Main battery and measure the length of the box with the plastic stay removed. Compare that length measurement to the physical length of the H7 battery you are thinking about buying..
DO, bring the Main battery you are replacing with you to the auto parts store, as they will take it and then you will not be charged a "core charge". (Approx. $10)
Here is a list of some H7's that are known to fit the JL/JT Main battery box with the stay/cleat removed:
(List Updated 9/7/22)
  • Interstate MTX-94R/H7 850CCA 80 Ah AGM
  • Odyssey Performance AGM94R H7 L4
  • Super Start Platinum H7 SSB94RPLT
  • Napa P/N 9894R H7
  • Duralast Platinum Battery H7-AGM Group Size 94R 850 CCA
  • Batteries+ X2 Power H7 Group 94R SLI94RAGMDP
  • EverStart Platinum AGM Battery, Group Size 94 H7 850 CCA (Walmart)
  • Optima YELLOWTOP AGM YEL94R DH7 Group 94 880CCA
If you installed an H7 AGM battery and it properly fit the Main battery box on a JL/JT and it is not on the list above..... Please post below and let everyone know. I will update the list to include the one you mention.
For Aux battery change the easy way and more battery related info read here:
https://www.jlwranglerforums.com/fo...ent-the-easy-way-pull-the-fender-flare.56807/
DieHard Platinum AGM Lead Acid Battery, Group H7, 850 CCA, $202.00,
3 yr warranty. Factory cloth cover fit.
Brad41
S. Indiana
18’ JLUR firecracker red
OldBlue
Doug
Chatham Twp, OH
See my Signature
@Brad41
Please do. I'm thinking about buying the same one.
blnewt
New Mexico
Just bought this one on Amazon. I’ll report back…
Nice, will be waiting for results, hope it works out well.
