“Service shifter” wire harness issue
GSLSE21B
Fair oaks
2021 jLURD
Had an intermittent “service shifter” message flashing on my dash today . I found the wire harness in the front passenger wheel arch was touching the egr tube . Moved the harness behind the heat shield and solved the issue .
Jeep Wrangler JL “Service shifter” wire harness issue B8B5A9C6-FE80-49B8-80B3-7BBB03743F87
Plongson
Paul
So. Utah
2020 Wrangler Rubicon JL Diesel, 1984 Jeep Cherokee XJ
Retired engineer and business owner. Vibration analyst, reliability specialist.
Wow...good work! But how the heck did you find that??
GSLSE21B
GSLSE21B
Fair oaks
2021 jLURD
We were on icehouse road 5 miles from the rubicon when it started flashing on the screen . I pulled over and started pulling on the different harness clusters while my wife watched to see if the message flashed . The wire harness was just barely touching the egr tube .
Plongson
Paul
So. Utah
It's scary how much shit is crammed under the hood and how much has to be insulated from the heat...looks like it's just asking for trouble.
omgoddard
CLT, NC
2021 Diesel JT
@GGSLE21B - just wanted to say thanks for the post and photos! My 21 eco diesel started this error w/ 250 miles on it. I too found the harness outside of the heat shield. I tucked it back in and it has been good to go. I might take it another step and wrap the harness w/ some heatshield tape.
Thanks!
gato
New England
2021 JLUR
Can you guys please explain exactly where that harness is and how to get to it? Do we have to pull the wheel well liner?
I'm having the same problem and checking for all reported possible solutions.
Thanks.
GSLSE21B
GSLSE21B
Fair oaks
2021 jLURD
Thanks.
Right front wheel opening
Jeep Wrangler JL “Service shifter” wire harness issue 02B14340-D1F6-439D-8294-492D81BD8C58
gato
New England
2021 JLUR
No Spark V6
Chicago NW burbs
2021 Rubi 3.0 GCM
Finally crawled under mine today to address this. My harness was touching and you could tell there was some contact but it wasn't close to cutting any wires yet. I didn't feel like pulling the wheel and liner so did my best to address it from underneath. There is a zip tie that hooks onto a stud so I pulled that off then used a small screwdriver to release the zip tie and slide it down a little, then snugged it up again and put it back on the stud. Now it's closer to the body and not rubbing anymore. My zip tie was like the other posts, closer to the center of the wrapped area and I just moved it down(harness up) to eliminate some of the slack.
