gts
- Greg
- Aug 11, 2018
- Prescott, AZ
- 18 JLR
My experience-
Lifted JLUR (Mopar lift) 18, manufactured 3/18. Started getting the service locker light intermittently while wheeling, eventually started showing up more often. My code scanner showed a C144D code, pointing at the front locker.
Important to note that if you turn the ignition of the jeep off this code will clear, so you will not see a code unless you have not powered the jeep off after getting the light.
Pulled harness from diff to driver side firewall, both signal wires showed drops of continuity when the harness was handled in proximity to the first wire clip (the one that secures the wire to the upper control arm)
Suspect that I did pull the wires too taught on a droop, ordered and installed new wiring harness (68325447AD- the one removed was AC, could not see any physical difference between them) I also did not connect the second wire clip up from the differential to provide extra tolerance for droop. So far no more messages.
