“Service Axle Locker System” Light On
mgroeger
Hurricane, UT
2018 JLUR "Fat Ninja", 2020 Acura RDX A-Spec
I'm waiting on my dealer to decide to fix it right.... So far they have insisted on changing everything but the axle, even with my information and protests...
But in the interim, I have discovered that JScan can still command the lockers to work, even with the axle fail light on and the factory switches locked out. Last weekend I went on an short trail and did get to use my lockers.
That's good to know about the Jscan.
4x4tographer
Ryan
Phoenix, AZ
2018 Jeep Wrangler Rubicon
All depends on the dealer. I could easily see a dealer giving you grief based on some of the posts on this forum and other dealers won't even blink an eye.
Personally I would just buy the Z Automotive harness and call it a day. Avoid all the dealership BS and hassle and the reality that the new axle may fail with a week or never fail... but if that one fails and your out of warranty... you'll be buying the harness anyway.
Totally figured as much. I have my JL getting looked at for a few other warranty items and locker issue happened to pop up the day before my appt.
My plan is to see if they'll honor the warranty. If not, bypass cable wins until a real fix from Jeep comes out.
Jondrew
Bob
Central Fl
2018 Rubicon
Well I guess I joined a club I really don't want to be a member of. I got this service light a couple of weeks ago. My son is a service writer at a Jeep dealer and has had it for 2 weeks now and they cannot figure out what's wrong. They've replaced the actuator, board, fixed some connectors. He's at his wit's end and now has to bump it up to Jeep. This really sucks. I love my jeep, but hate this computerized BS when it goes sideways and no one can figure out what to fix.
mgroeger
Hurricane, UT
Have you shown him this thread?
OutlawBeard
Kansas City, MO
2021 JLUR Gecko Ordered 5/4/21 Delivered 8/27/21
Someone found out who makes them but you can't buy them. The sensor is a hall sensor that monitors the state of the locker. Z Automotive (maker of the Tazer) has a harness you can buy for $75 which replaces the sensor and basically feeds a "everything is groovy" state back to the computer so you can engage and disengage the lockers without issue.
The harness is $179 per axle , if they were $75 I'd buy them now for when mine inevitably fail.
mgroeger
Hurricane, UT
Those bastards... lol. That used to be $75.
MojitoJLUR
Detroit, MI
2018 JLUR Mojito
$75 seems like a much more fair price. I get that there is R&D tied into it, but $179 seems a bit high. I had to bite the bullet because that is cheaper than them swapping out the axle and me having to regear again.
mgroeger
Hurricane, UT
Even $75 was a bit much IMO. @chevymitchell built the same harness for $6.
4x4tographer
Ryan
Phoenix, AZ
Well - back from the dealer - they couldn't replicate the issue, so I've got it back.
Out of curiosity, do you guys think potting the sensor now (after it's displayed some intermittent 2H locked messages) will help stave off the issue?
Or just buy-once, cry-once and get the Z Locker OEM?
mgroeger
Hurricane, UT
If you have already started to throw locker codes on your dash it's too late to pot.
SmallCheese
Cheesus
Canada
2 Door JL Rubicon
Shame to hear about the locker issues, I tip my hat for those dealing with them.
Anyhow, I fixed my intermittent service axle locker light, my problem was a severed wire due to an over tightened zip-tie (from factory).
Symptoms: Intermittent "service axle locker system" message appearing on dash.
Location: Front Differential (zip-tie was directly above diff, front driver side)
Fix / Solution: Spliced in new piece of wire
Duration of work: 4 coffees
The harness affected was located behind front driver side tire, from engine bay to the differential. The specific zip-tie was located directly above the diff.
Before I get too far, I will say this one puzzled me for a bit, (in terms of diagnosing) . I spent quite some time wiggling wires to see if I could prompt the light, to no avail, but opening and closing the back of the jeep would (at times) activate / deactivate the light. Go figure.
I was able to diagnose (partially) because of the Z Locker doohickey (I thought it was probably the sensor issue because extensively wiggling the wires did nothing). Plugged it into the back, nothing changed, intermittent light still activating. When I plugged it into the front, the light stayed on, meaning, that my moving of the harness unquestionably triggered the light, which was indicative of a broken wire.
Anyways, below is a pic of the harness in full, in case anyone needs a visual. 3 connectors total for full removal and inspection.
Below is a pic of the exact location for the harness, if you are like me and need a lot of pictures.
Good luck out there with your rigs !
FWIW: If you have this exact issue, exact location, turn your tires all the way to the right for more access... took at least 1 coffee before my noggin started working.
mgroeger
Hurricane, UT
This thread seems to show replacing the rear axel fixes the problem most of the time. Has the rear axel been replaced yet?
Replacing the axle is not a real fix because they are replacing it with an axle with the same sensor in it that is prone to failing. Until they fix the real problem... the sensor... this will continue to be a problem.
Extreme Terrain
