‘20 Rubicon JL The Beginning!
NCJL
EastBay
2020 Rubicon
Purchased 2/20. Mods start 3/20.
Stock Rubicon W3.6L Leather, Nav, Tow Package, Steel Bumpers
Overland type Build.
Parts ordered on the way:
AEV Pintler wheels
BFG All-Terrains 315/70/17 (35’s)
AEV 2.5 DS lift kit
Mopar tailgate reinforcement
Mopar cargo liner
Sync MFG front and rear Trac Bar W/frame mounts
SteerSmarts HD Tie rod and Drag link
Warn Zeon 10-S Platinum winch
Rugged line winch Mount
Rubidozer
North Carolina/West-Central
2020 JLUR, 2018 Jeep JLUS
AEV Pintler wheels
AEV 2.5 DS lift kit
Mopar cargo liner
Where are the “After” pictures with the lift on???????????????????
NCJL
NCJL
EastBay
2020 Rubicon
Update. New wheels and tires installed. Changed from Pintler to Savegre wheels do to availability. Winch installed, however have a clutch engagement problem. Lift install... next weekend.
NCJL
NCJL
EastBay
2020 Rubicon
Very happy with all the AEV products. We had the same issue with tires. Bigger is better but cost more to do right. 37” Might be in the future
Biohazard
Nathan
Bristol, TN
2018 JLUR (sold May 2020); now own 2020 trd pro Tacoma
My 37’s do great, provided they are paired with a good lift and steering stabilizer, and a retune of some type to get your speedometer and transmission back to accurate. I’ve had it up to 95 mph and was smooth and stable. Routine 75mph with no issues at all. Definitely would be disappointed that I didn’t do 37’s if I was in 35’s.
NCJL
NCJL
EastBay
2020 Rubicon
Haven’t posted to this in awhile. Purchased an off-road trailer that we picked up in April that quickly become the purchase from hell! The trailer will get its own post later. Just took all my time, money and frustration to a new level of unbelievable.
we added the following to the Jeep build
metalclock belly skid system, control arms, front/rear bumpers and tailgate tire carrier.
jlur_2019
Oliver
CA
2019 JLUR
Is the pic camping and these two still w 315/70/17 tires or is this with 37s?
NCJL
NCJL
EastBay
2020 Rubicon
All the pics so far are the 315/70/17 tires. Update with some 37 tires next week.
jlur_2019
Oliver
CA
2019 JLUR
Oh wow. Most of the times 3” lift w 35s looks weird but ur Jeep looks good.
Did u end up installing all 8 aftermarket control arms? Why? Was it to get better caster n pinion angles or was it more bc the geometry correction brackets that come w AEV kit sit low and reduced ground clearance? Which control arms did u go with?
Sorry for all the questions but u installed the lift I’m thinking of installing n it looks like u use ur Jeep in similar manner (camping/pulling small trailer/etc)
TIA
NCJL
NCJL
EastBay
2020 Rubicon
Yes, replaced all 8 controls arms. Still have the AEV geometry correction brackets installed. The new control arms are set to factory length. I’ve had factory arms bend in the past, actually I’ve bent every lower control that I’ve ever installed on my TJ except 1/2” wall custom made arms. (Spent a lot of time in Johnson Valley.) I have no plans for extreme rock crawling with this Jeep, however towing a trailer at max tow ratings in the desert and moderate trails I felt it was money well spent.
The control arms MetalClok
NCJL
NCJL
EastBay
2020 Rubicon
Change to Teraflex Nomad wheels for the 4.75” BS. About an inch more than the AEV wheels and 37” BFG AT tires.
The side x side pic- right is the 37” Left is the AEV wheels with 315’s on a stock JL
Gibson Leatherworks
