- Oct 7, 2019
- Metairie, LA
- Website
- www.oraclelights.com
- 2019 Jeep Wrangler JL
- Occupation
- Automotive LED Manufacturing
Save on your Jeep's facelift with the ORACLE Lighting ProSeries Vector Grill...this forum-exclusive deal only lasts through January! Use code VECTOR15 at checkout
See our thread below for more info!
The ORACLE Lighting Vector™ Series Grill for the Jeep Wrangler JL and Gladiator JT is the first full-featured replacement grill with integrated LED light emitters for Low Beam, High Beam, as well as a Dynamic LED DRL. This unique design is equipped with an array of application-specific LED lighting features unseen in any other Wrangler lighting system.
The new PRO-SERIES revision of the Vector Grill includes major improvements to the quality and durability of the LED DRL Modules. These modules are now robotically sealed to create an Ingress Protection Rating of IP68 which will keep moisture out of your fixtures even from exposure to pressurized water spray and brief underwater submersions. The DRL modules are now mounted with hardware rather than adhesive to make these parts easier to remove for grill painting and maintenance.
Each LED emitter can independently adjusted in order to put a focused beam of light on the road without blinding oncoming traffic, this is especially important for lifted Wranglers. The separate driving and Low Beam lights allow for proper light distribution for optimal road legal light coverage. The Vector™ Series Grill features an impressive 5,600 Combined Lumen (Raw Lumens) Low Beam with advanced optics for precision lighting that illuminates the road for increased driver visibility without creating glare that can blind oncoming traffic.
7,200 Combined Lumen High Beam for illuminating any dark landscape. The headlight wiring connection is "Plug and Play" thanks to the included harness adapter which plugs into the factory socket. The DRL module is wired in to the vehicle’s fuse box with the included fused wiring adapter. Installation takes 1-2 hours for most beginners and requires only basic tools for DIY installation.
Additional features of the ORACLE Lighting Vector Series Grill include an integrated LED Daytime Running Light (DRL) which increases driver safety by making the Wrangler more visible to other drivers on the road. This DRL also features a unique "startup sequence" Dynamic LED display. The components of the Vector Grill were CAD developed to insure that the fit and finish of this product matches factory quality and fitment. The ORACLE Vector™ Series Grill was designed in the USA and has been granted USPTO design patents and has other patents pending in the US and countries abroad.
See more about the new Vector LED Grill Here: www.oraclelights.com/products/vector-jl-jt
