JeepMike1
Using the 1/2" Hex Bolts WORKED!!! Thank you.Ok, so I had enough of feeling like I was falling into the dash especially after a 300 mile trip I took. I’m not spending 79.00 on spacers from fleabay. So I went to Home Depot and bought some 1/2” hex nuts. They work as a spacer even the way the left front bracket is made. They fit perfect and gave the bottom cushion about an inch or so tilt up. 100% better. Just remove the 2 front bolts loosen the rear bolts and the 1/2” nuts will fit underneath both front bolts. Tighten up and your good to go. Total cost was 55 cents. Probably easier than trying to put a bunch of washers. So for you big and tall guys like I am this seems to work for now.
