d3vils-advocate
If you could choose your bumpers again, would you buy aluminium? Would you prefer it to be for the front or back if you only had one option? Or would you go back to steel?
Very interested to hear on this one as well...
Really like the look of the new Rival aluminum bumpers - but I currently have OEM steel.
That's exactly what I was thinking, and it cuts down some of the front weight as well.When I do mine it will be Alum up front, steel in the back. Back takes a lot of abuse over rocks and being dragged dropped onto them. The front, if it gets anything, is normally just scrapes.
Agreed. I'm also interested in a swing-out tire carrier on the rear and AFAIK that pretty much limits one to steel back there. If AEV *ever* gets their bumpers to market it will be interesting to see as there's a lot of promise of high strength/low weight with their boron hot stamped steel method (though no doubt it will be priced accordingly).When I do mine it will be Alum up front, steel in the back. Back takes a lot of abuse over rocks and being dragged dropped onto them. The front, if it gets anything, is normally just scrapes.
Gen right makes an aluminum Tire carrier.Agreed. I'm also interested in a swing-out tire carrier on the rear and AFAIK that pretty much limits one to steel back there. If AEV *ever* gets their bumpers to market it will be interesting to see as there's a lot of promise of high strength/low weight with their boron hot stamped steel method (though no doubt it will be priced accordingly).
Yes, the tire carrier is Al but it is still a tailgate hinge mount. What I'm interested in is the carrier that is bumper/frame mounted and, AFAIK, that limits one to steel.Gen right makes an aluminum Tire carrier.
https://genright.com/products/jeep-jl-swing-out-rear-tire-carrier-aluminum.html
I’m looking at the Rock Hard aluminum rear bumper and in two different places I’ve read that shifting the tire carrier up is required with more than a 33” AND also bigger than a 35” tire. I don’t know which one to believe. I’m looking at a 33.9” max right now. Do you have any insight on this? ThanksWent aluminum front and rear. Both Rock Hard.
Was in same boat and looking for a bumper mount carrier. However, will not go bigger than 35" and a hinge replacement mount (like EVO, Rusty's, Ace, etc.) will be just fine for me.
Is it because the tire will hit the bumper and would it be possible to cut as much as an inch of an arc out where contact would be made?I have 35" tires and yes, I had to move the tire up to clear the bumper. I was able to adjust my (Rusty's) tire carrier to get the tire where it is touching the hinge arms for stability. It would have been ideal to have the tire down a couple of inches to put it more with the centerline of the tailgate, but the set-up is just fine.
