YippieKiYayMrFalcon
yes, you need to remove the grill (6 pins on top and then pull the grill out to release the pressure clips). Then remove each headlight housing (3 bolts each) and remove the dust cover from the back of each housing. Give each bulb a 1/4 turn to remove them and replace the bulbs. It’s about a 20 minute job tops.How hard were the bulbs to swap out? Did you need to remove the grill to complete?
there are plenty of videos that show how to remove the grill and lights out there if you’d like to see how it’s done.
