Which mount plate for stock steel bumper and smittbilt winch?
Jasonangel
Jason
Houston, Texas
2018 jeep wrangler jl Rubicon
I have the Warn winch plate, if I were to do it again I would choose another with the smittibilt x20 gen2 comp. It sits too close to the grill for my taste. Not enough room for a neoprene cover to go on with it. I had to notch the cover to fit as the back of the winch where the wires go is pretty close to touching. I would prefer it to sit a little further forward.
Do you know of any that sit a little more forward? I would like to get a plate that would allow me to use the cover.
Cypher
J
AZ
Cybersecurity Leader
I do not. I have seen few others with the issues and other winch plates
bam9382
2018 Jeep Wrangler Rubicon
Same here. I got this plate + the D-ring add ons with a SmittyBuilt X20 Winch. Easy mounting, Winch sits nice and low. Great instructions with it too.
@MacombRoger Did this mount allow you to keep the factory skid plate? What has been your experience with it so far? Not much info out there on it? Have you used the winch? Has the plate held up? Any bending or issues at all? Thanks!
bam9382
I went with this one as well and it is beefy! I have a Smitty 10k X2O mounted to it and it works perfectly.
I am sure the others mentioned above are great as well but I have heard from some of the members in my club the JCR one flexes a lot when hard pulling, I havent seen it first hand so I cant confirm so take this with a grain of salt.
@brianP What has the experience been with this winch plate so far? Has it held up? Any flexing or bending? Were you able to use the factory skid plate without modification?
bam9382
bam9382
Sorry for 3 posts at once above... Not trying to spam just need to buy one ASAP and looking for advice asap thanks guys!
Tunesoul
Kirk
1999 Jeep Wrangler Sport, 2012 Subaru Outback, 2018 Ocean Blue JLUR
Owner of a Mobile Auto Paint Touch Up Co.
Rustys. :like:
CarbonSteel
2023 Ford Bronco Wildtrak
I installed a Warn plate with a Smittybilt X20 12K winch with no issues aside from some of the bolts being too short.
Tunesoul
Kirk
MacombRoger
Roger
SE Michigan
2018 JLUR Ocean Blue
Solution Architect
Yes, factory skid plate bolted right back into position. I have used the winch a few times now, both for my own recovery and to help others. No issues with the mount at all, no bending or anything. Its very stout.
Baladen
Oregon
2018 JL Rubicon I4
Technician
I went with the Rusty's winch plate also, specifically because it did not push the bumper forward and mess up the skid plate install. I put a Quadratec Stealth winch on mine, and the generic neoprene cover I got fits just fine.
gm920
Gary
San Diego County Mountains
2019 Jeep Wrangler JLUR Billet Silver
Aircraft Maintenance Technician (Retired)
I think Rockhard has the best winch plate.
The Rock Hard winch plate is a very well built plate, but it does not work with the SmittyBilt XRC 9500 Gen 3 Winch. The rear tie bar hits the grill before the bumper is fully bolted on. I believe it sits higher overall to begin with and the rear is angled upward making this a no go for the SmittyBilt XRC
99wishes
2018 Jl Moab
Interesting. I know about the 10 degree tilt, how do you know it sits higher?
