joelmilehigh
- Joel Spicola
- Nov 19, 2019
- Denver, CO
- 2011 Tahoe
- Complete Dynatrac JL Pro Rock XD60 Full Float Standard-Cut Rear Axle Assembly
- Custom Machined Dynatrac JL XD60 Standard-Cut High Ground Clearance Heavy Duty Nodular Iron Full Float Rear Axle Housing,
- Includes: - 4.0“ Diameter x .25” Thick Wall Lightweight High-Rigidity 4130 Chromoly Tubes and Heat-treated Chromoly Full Float Fixed Spindles
- Installed - Axle Width 70.0“ - XD60 Heavy Duty 3/16” Thick Fabricated JL Rear Coil Spring Suspension Bracket Assembly Kit with Raised Track Bar Bracket
- 4.0“ Tube
- Installed Differential
- ARB Air Locker
- D60
- 4.56+
- 35 Spline
- Installed Ring & Pinion
- D60
- 4.88 Ratio
- Standard-cut
- Installed Ring & Pinion Set-up Kit, Pro 60
- Rear, Standard Cut Pumpkin, Includes Carrier Bearings, Installed Yoke, D60, 1350, U-Bolt, Installed U-Bolt Kit, 1350 Yoke
- Included Brake & Wheel Hub Assembly Kit
- XD60-Std Cut Rear, 2018 JL, Full Float, 8 on 6.5”, J8 Disc Brake Assemblies, Wheel Hub Assemblies, Installed Shaft, Full Float, Rear, 35 Spline, Custom Length, Installed Gear Oil, GL-5 85W-140, Installed to Axle Assemb
Local Pick Up Available
Shipping Available - Buyer Pays for Shipping Cost
