Gerry878
It actually rubs before steering lock. I’ll try to take pics in good lighting to show you. Thank you!Get a tape measure and see if your driver's side wheel sticks out further from the jeep than the passenger side with the wheels pointed straight. If that is the case then your track bar is technically too short.
If both wheels are the same distance from the jeep, then your axle is centered. If you are having the same problem as OP, with your passenger tire rubbing at full driver lock, then your steering stops are not evenly adjusted. You will need to extend the driver's side steering stop to prevent the passenger tire from turning in too much. It's extremely easy, remove steering stop bolt, add washer, put bolt back in, test, keep adding washers until it doesn't rub anymore.
