CarbonSteel
As a hard top 4 door JLUR owner, I, and assume most of you, experience a “buffeting” effect in the interior at speeds between 35 and 45MPH (and sometimes at higher speeds as well). I solved my issues with that today based upon reading a few posts here. The issue is the roof flexes (similar to a drum beating) and thus pressure and sound are introduced into the cabin.
For $12, I have reduced the buffeting sound to near zero. I no longer notice the noise or the pressure at any speed. I used a 3” diameter x 36” long foam roller and covered one-half of the roller (except the last 4” inches on each end) with 1” pipe insulation. This is because (at least on my JLUR), there is a cavity in the center of the roof that required a bit more packing to close the gap.
I will figure out a way to dress it up later, but for now, I am very happy to have eliminated something that should never have existed.
Foam roller - https://www.amazon.com/gp/product/B001RQ3VBQ
Pipe insulation - https://www.homedepot.com/p/Everbilt-1-in-x-6-ft-Foam-Pipe-Insulation-ORP11812/204760805
Hey, @JeepCares – this is a design issue that could be easily resolved by strengthening the roof (side to side) directly above or slightly behind the passenger overhead support bar thereby eliminating the roof flex.
