GreyFox
The shed is filled with rodent deterrent plus one of the best mousers in the state is a member of the family , meet SHANTI , she weighs in at 14 lbs and is detrimental to local rodents health !
Where did you get those hooks from?! (the one holding the soft top)I used the same idea / hardware as others here. Windows in the storage bag laying flat on a shelf. How deep are they? I went to a couple hardware stores yesterday just looking for similar hooks to screw into my garage studs, but I couldn't find anything deeper than 7 inches. I know, 7 inches would normally be adequate. At least, that's what I've been telling myself.
I don’t want to speak for Dudley, but they look a lot like these....Where did you get those hooks from?! (the one holding the soft top)
Deep enough though?I don’t want to speak for Dudley, but they look a lot like these....
Heavy Duty Wall Mounted Steel Padded Arm Hanger in Gray 50 lbs
https://www.homedepot.com/p/202305548
@bpdunsta is correct; I bought them at HD. They are plenty deep enough.Where did you get those hooks from?! (the one holding the soft top)
Can you take a picture? When I tried putting mine on top of the Racor, I could not get it to sit right. Had to have one of the “arms” kinda hanging....which would make it so I couldn’t easily use the lift to remove the hardtop should Mother Nature allow it.Mine lays flat on my Racor hard top hoist. While I have a storage bag for the winows, I kept the long brown box that the windows came in and lay the box on top of the top.
On the bottom of the Racor sits the top on its side and facing it is the Freedom top storage bag. The the space between the two, I laid the plastic track panels that the top slides on. On top of that sits the original box that the side/rear windows came in. And yes on top of that sits the snap in carpet for our boat along with two bow filler cushions.Can you take a picture? When I tried putting mine on top of the Racor, I could not get it to sit right. Had to have one of the “arms” kinda hanging....which would make it so I couldn’t easily use the lift to remove the hardtop should Mother Nature allow it.
Maybe I’ll give it another go this weekend. Thanks for the pictures!On the bottom of the Racor sits the top on its side and facing it is the Freedom top storage bag. The the space between the two, I laid the plastic track panels that the top slides on. On top of that sits the original box that the side/rear windows came in. And yes on top of that sits the snap in carpet for our boat along with two bow filler cushions.
Hope that helps.
