eder214
I'm deciding between this two tire carrier, but I need some help deciding which one is the best. I plan run 37's. What are the pros and cons for each carrier? What I like about Smittybilt is that it looks like it can be adjusted depending on the wheel offset so it be closer to the tailgate. The Rugged Ridge I like that you can tilt the carrier upward which I also like since I plan to get a fastback top down the road. The only thing is that I'm not sure if you can adjust the Rugged Ridge carrier for the wheel offset. Any help is appreciated.
