Extra switch on A pillar lights.
Memphis Peej
PJ
Memphis
Pilot, Acura TSX, 2019 Moab!!!
I ordered the Pro Comp 75w Wide Angle Cube LED Lights from a suggestion on the forum. They come with a wiring harness with a built in switch.
I have the factory installed aux switches so I don't need the built in switch. I’m not sure what to do with this included switch as it’s wired to the relay and has about 10 feet of cable.
What do I need to do to bypass this and just use my factory switch? I will include a pic when I get home.
Memphis Peej
Memphis Peej
PJ
Memphis
Here is the photo
77RRAD
Ron
Las Vegas
2019 JLUR
All you need is 1 red and 1 black wire.
Hook red up to the power harness (aux 1 2 3 or 4) and black to ground from the light.
Ron
Memphis Peej
Memphis Peej
PJ
Memphis
Ron
Ron,
Thank for the response. I understand that but what do I with the switch. It's wired into the relay. I guess I can cut away the shrink wrap and see if I can disconnect it from the relay?
EDH_JL
State of Jefferson
2018 JL Sport
Ron,
You don't need the relay. The factory aux switches go through a relay so you can just hook straight to the power with regular wire like 77RRAD said.
Dagwood
Alabama
2019 Jeep JL, 1999 Jeep xj, 2008 Scion XB, 2015 Scion XB, 1966 Ford F100, 1969 Oldsmobile
Power and ground as stated, cut the rest off the harness and through away. Unless you're a pack rat like me and keep it for something else years down the road.
77RRAD
Ron
Las Vegas
2019 JLUR
I would just go buy some black and red wire and save the harness.
Ron
Howi
Cheshire, UK
Jeep Wrangler JL 2019
If you are desperate to use that harness just leave turned on and hide the lot
Memphis Peej
Memphis Peej
PJ
Memphis
Happy to report project completed. Thanks for the advice. I ended up cutting most of the harnesses wires away like suggested. Works like a charm!
Thank you very much.
Josht10
Josh
Amarillo, TX
2019 Jeep rubicon unlimited
How have they been at night? Worth the money?
Memphis Peej
Memphis Peej
PJ
Memphis
Excellent! These are floodlights and they cast a very wide beam. Certainly brightens the periphery tremendously, as well as adding significant lighting height.
The lights are made very well. Solid casing and build quality. The wiring is heavy gauge and the connecters are strong. I did remove the relay and switch as I didn't need them due to having the factory Aux switches.
I did get these for $75 for the pair via a post on this forum. So for the price I paid I am extremely pleased!
