ChattVol
The main reason I went with the rock trac swap before regearing the diffs is it improves the crawl ratio twice as much as regearing the diffs to 4.88. With a 6 speed, the t case swap was a more meaningful improvement.Wow, thanks Chevy for all the responses. Ill definietly keep that offer in mind. Once i am able to put some funds together, id love to take you up on that and regear up at your place just to have someone around to bounce questions off of if i ran into an issue.
As for the tcase regear, good to know. I was wondering myself which would be cheaper, regearing diffs or tcase. Aside from the beneifts from each, money wise, diffs might be cheaper in the end and then you also get better on road manners as well.
The benefit of the rock trac 4:1 is it would be an easy swap id imagine and wouldnt require so many tools to do vs the diff regear.
