Got my kit installed today, glad I did I had a nice coating of oil all over the turbo inlet.
Very nice, thanks for sharing! And yeah, what have you been doing, driving on dirt or something?!Also dam my engine is filthy...
Nope Mike is a Mall Crawler!!!Very nice, thanks for sharing! And yeah, what have you been doing, driving on dirt or something?!
Thanks,
-Steve
Those are great photos. I took the plunge yesterday and ordered a can. All these pics and the video should make my install easier.Got my kit installed today, glad I did I had a nice coating of oil all over the turbo inlet.
Want to know this as well.Those are great photos. I took the plunge yesterday and ordered a can. All these pics and the video should make my install easier.
side note: I plan on using CRC valve cleaner on my 2.0T religiously. Where's the best spot to spray in to avoid the sensor? In the intake opening in the last photo?
Thank you @Fusilli Jerry ! I'm also unsure on where would be the best place to spray a valve cleaner on this one. Spraying pre-turbo is really going to reduce the amount of cleaner that actually gets to the valves. The best bet would be a line that goes directly to the intake manifold, but I'm not sure of there is one. You might be able to pop the bypass valve off the intercooler pipe and just spray it through there. I'll see what I can find in our factory diagrams and data.I’m not 100% sure, I haven’t used it before and I assume the engine needs to be running. Since you wouldn’t want to get it on any sensors I guess the turbo inlet would be the best bet.
On second thought, i'll probably just rely on changing the oil every 5k and installing the catch can. I'm willing to bet using CRC sprayed into a vacuum line will throw a tone of codes, and I've got to draw the line somewhereThank you @Fusilli Jerry ! I'm also unsure on where would be the best place to spray a valve cleaner on this one. Spraying pre-turbo is really going to reduce the amount of cleaner that actually gets to the valves. The best bet would be a line that goes directly to the intake manifold, but I'm not sure of there is one. You might be able to pop the bypass valve off the intercooler pipe and just spray it through there. I'll see what I can find in our factory diagrams and data.
Thanks again!
-Steve
Please let us know what the code is. It looks like everything is installed correctly in your photos—the only thing I can see is maybe the hose is pinched up by the intercooler pipe, but I wouldn't think it would be enough to cause an issue.So driving to work I saw a huge drop in MPG and then this I will grab the code reader and check it out at lunch and report back.
Good news the code is the same one that people have been reporting after intake installs. P1CEA for the purge flow monitor.So driving to work I saw a huge drop in MPG and then this I will grab the code reader and check it out at lunch and report back.
Interesting, do you also have an aftermarket intake installed?Good news the code is the same one that people have been reporting after intake installs. P1CEA for the purge flow monitor.
I do I have the S&BInteresting, do you also have an aftermarket intake installed?
Thanks,
-Steve
I do I have the S&B
