TazerJL Feature Requests
WXman
Central Kentucky
2018 Wrangler Unlimited
I'd like the option of operating the windows with the key fob like what the Ram 1500s are doing.
drdriller
Houston
2019 jl
When key fob leaves the Jeep, have dic state, Elvis has left the building
Multiple places..
It use to allow you on 11.0.6 I'm guessing it would allow you to but it wouldn't actually change the minimum requirement set point?
@freddiegs
Was problematic. Joe had to remove. So, not gonna happen..
Kidder212
Tom
Tennessee
2018 JLUR 2.0L turbo
I just requested turbo saver mode that lets engine idle for 2 minutes to cool the turbo before total shut down
Kevin Mojito
Washington
2019 JLUR Moijto 2005 TJ AEV Hemi
Not sure if it can be done.
2 Low range, by turning FAD off so it does not engage front axle?
ArmyJeeper
Reston, VA
Own a JLURubicon
Retired US Army
Can you make the Blind Spot Warning System work without the doors? Maybe a light on dash or Uconnect screen.
RocketScientist
Tom
Massachusetts
2020 Ford F150
Ability to enable autodim mirror
I added correct harness and mirror. Mirror has power and the SOS/assist buttons work (well, can’t get FCA to add Guardian as my “Jeep was not delivered with this option”)
The autodim mirror option does not show up in uconnect. I would think this could be an easy change?
MyJlU
TJ
The Ocean State
2018 JKU Sport
Sr Product Line Researcher
danny01
Miami
2018 JLU
A toggle for enabling the "Daytime Running Lights" customer programmable feature to show up in the UConnect Lights menu.
This is especially for Sport and Sport S owners who want to activate factory DRLs after switching to the Morimoto Sequential DRL/Turn Signals. Even though you can switch DRL region to US and set location to Dedicated on the Tazer, they still won't work because the BCM also checks for the UConnect DRL setting to be set to ON, which doesn't show up on Sport models from the factory, and is OFF by default.
@joe@zauto
