Concealed Air Fitting in the JL Fuel Door
NextDan
Peak Sponsor (Level 2)
Grand Junction , Colorado
www.nextventuremotorsports.com
1949 Willys VJ, 1973 Jeep Commando, 18 JL , 21 JT
CAD Designer, Adventure Machine Outfitter
For anyone looking to clean up an existing on board air setup, or just add another convenient/concealed air fitting on their JL, we are now offering our JL Fuel Door Air Fitting Kit separate from our full JLU OBA kit. This kit slightly relocates your fuel filler neck to the aft of the JL in order to make room for the included push button air connection. We love the push button air connections; way better then the common "push to connect" fittings that sometimes result in an accidental disconnect upon connection in my opinion. This is a perfect way to finish off any on board air setup!
There's some drilling and trimming/dremling of plastic required, however the included cutting template makes it pretty straight forward.
This kit includes a stainless steel fuel door plate, push-button style air hose socket, bulkhead through wall fitting, mounting hardware, and a reducer to allow the bulkhead fitting to work with the most common size lines used to supply air. Your factory fuel cap, and fuel door are reused.
crbrenny
Chad
Palmetto, FL
2019 JLUR Sting Grey; 2021 JLR Gecko
Engineer
Ordered one today :like:
Karnak
Yan
Ottawa, Canada
19 JL 3.6 Sport S - 2 door
government
Jeep Wrangler JL Concealed Air Fitting in the JL Fuel Door Fuel Door Image 2
would love to see the face of people passing by as you're "filling her up" with air....lol...that last picture is what it looks like, love it!
rustyshakelford
Brett
Navasota, TX
2019 JLUR-8 speed 2020 F-350
We’ve installed these and have to say they are awesome for anyone wanting a clean and protected solution for their fill point
brett
FreedomFur
Elliot
Concord, NH
2021 JLU Willys
brett
Brett - Sorry to revive an old thread.
What parts did you use to run the air hose from the inside to the fuel door? I want to protect the hose from heat. Also, where did you run it from inside to out? Did you use a drainplug?
I have my twin ARB mounted with the MORE mount in the rear and am getting tired of hooking up to the air chuck in the trunk. Wanting to run it to the fuel door or to a chuck mounted on the rear bumper.
