Do we need a torque wrench for oil pan and oil filter?
Ronnie S
Ronnie
Hamburg Township, Michigan
2019 Jeep Wrangler Rubicon Firecracker Red (2 Door) - 3.6L V6 24V VVT Engine Upg w/ESS - 6-Speed Manual Transmission
getting ready to change my oil and was curious if we need a torque wrench for the oil pan and oil filter? And if so what are the specs?
melendez69
Marc
Waxhaw NC
2018 3.6 JLR / 2013 911 / 2013 E92 M3
...huh?
You don't necessarily need a torque wrench, but it's a good idea...
About 20 ft-lbs (13mm socket) for the drain plug.
About 18 ft-lbs for the filter cap (24mm socket), but I usually tighten the cap by hand.
May The Force be with you... just not too much force.
Ronnie S
Ronnie S
Ronnie
Thank you!
morricus
Illinois
2018 Rubicon Unlimited, 2015 GMC Yukon XL, 2006 BMW M3
Invest in a Fumoto Valve, you never have to mess with it again. I've one on every one of my cars for the past 10 years, even race cars. They're glorious.
Ronnie S
Ronnie S
Ronnie
Thanks I’ll look it up! :)
OldGuyNewJeep
Don
CT
+1
LincolnSixAlpha
Arizona
No, hand tight plus half a turn or so with a wrench.
blnewt
New Mexico
Just ask @cosine he knows!
I tried the metric sizes on the filter cap & drain plug and found SAE sizes a much better fit, no slop like the metric sizes. If you have both SAE & Metric sets take a 1/2" on your drain plug & a 15/16" socket on your filter cap and see how much better they fit :)
Being light torque fasteners it's not as critical, but that plastic filter cap wouldn't take much to round off w/ a loose 12pt 24mm socket FWIW.
morricus
Illinois
melendez69
Marc
Waxhaw NC
...huh?
You're absolutely correct... I only carry/use SAE sockets with my JL... I'm just too accustomed to quoting in metric sizes.
Truth be told, this is my first American car (if you remove the F from the CA).
Dkretden
Denver, CO
2020 JLUR 3.6L
The thought of having a valve down there scares the heck out of me. I guess that they are proven and lots of folks use them but, I just might be too paranoid to put one on!
