Shift on the Fly Tuning, Tire Calibration, and Throttle Sensitivity Booster Now Shipping
Superchips JL
Summit Sponsor (Level 3)
Jeep Team @ SC
Sanford, FL
2018 JL Rubicon
Launched today 5/22/19
https://superchips.com/pulsar-jeep-jl-wrangler/
***Dyno chart updated - inadvertently had an incorrect chart on original. Thanks,
Pulsar for Jeep® JL Wrangler®
Power, Calibration, and Throttle Response On-the-Fly!
Hold onto the Wheel!
No seriously, put your hands on the wheel and then shift on the fly via your factory cruise control buttons! Your JL Wrangler® will feel like a totally different vehicle, after installing Pulsar. This all-new inline module connects directly to your factory computer and does not require any removal or swap of the PCM (computer) itself. As you may know, unlocking or swapping late model Jeep PCMs has been the process required to add power. That was before PULSAR! Now you have access to power, tire and gear calibration options, and instant throttle response directly from the driver’s seat. No sending in the PCM or downtime. Read further to review power levels and features. Once you take a look you’ll be ready to install Pulsar and make your JL Wrangler® the talk of the town!
Why Pulsar?
1) Pulsar adds power instantly with no PCM swap required
2) Install is simple and straightforward and does not leave you with any extended downtime
3) Offers shift-on-the-fly performance programming
4) Pulsar serves as 3 products in 1 – throttle booster, calibration tool, and programmer
5) Gives your JL a performance upgrade unlike any other available on the market today (bragging rights!)
Winning with Innovation
Superchips has invested heavily in resources to continue bringing the most cutting-edge products to market. This has been especially important to us with the Jeep® marketing. The Pulsar product line was introduced in early 2018 for the late model RAM HEMI engine marketing. Overwhelming demand and sales made bringing this innovative platform to the JL Wrangler® an easy decision. With Pulsar, you are getting an innovative product, tremendous features unlike any other on the market today, and a driving experience that has been engineered to leave you belong impressed. Review the video clips below to understand what comes in the box, how to install the Pulsar module, and learn how to manage the exciting features directly from your steering wheel. Prepare to drive equipped with the most exciting aftermarket upgrade available for the 2018-2019 Wrangler® JL 3.6L Jeep®.
PULSAR FOR 2018-2019 JL WRANGLER®
Power Levels 4 Performance Levels – Performance, Tow, Economy, Stock w/ Options
Power Gains 30 HP and 27 ft-lbs TQ
Shift-on-the-fly Yes – Using cruise control +/- buttons
Tire Size 20″-40″
Gear Ratio 2.00-5.99
Auto Start/Stop On/Off
Tire Pressure Adjustment 22-64 PSI
TPMS On/Off Yes
Pedal Response Adjusted Yes
Ronnie S
Ronnie
Hamburg Township, Michigan
2019 Jeep Wrangler Rubicon Firecracker Red (2 Door) - 3.6L V6 24V VVT Engine Upg w/ESS - 6-Speed Manual Transmission
@Superchips, does this still have all of the benefits of the Flashpaq PN 3876-JL tuner? If so then this is a no brainer with not having to swap out the pcu.
Superchips JL
Superchips JL
Jeep Team @ SC
Sanford, FL
2018 JL Rubicon
Hey Ronnie, just replied to your PM as well, but Pulsar really does all the Flashpaq will do with the exception of things like reading and clearing DTCs and some of the running light options. When it comes to power, tire/gear options, and throttle sensitivity increase - the Pulsar is an very impressive product.
Ronnie S
Ronnie
Ok cool! Does it also have the 87, 91 & 93 octane power selection of the flashpaq or does it just include the high performance option only?
Sorbs
Brian & Sunny
Colorado Springs
21' Ram TRX, 20' Gladiator LE
One question...Gladiator?
Superchips JL
Superchips JL
Jeep Team @ SC
Sanford, FL
2018 JL Rubicon
We suggest running 91 or higher for max performance gains, but any octane will work
Sorbs
Brian & Sunny
Colorado Springs
We have very good news coming soon there!
I’m waiting on my Launch Edition delivery and this will be an excellent mod when available. Thanks!
mrhumble1
Jason
Denver, CO
JL Rubicon, 2-Door, Manual
Those HP and torque numbers are nice. Was this tested on a manual or automatic transmission??
Looking forward to seeing someone here test this out.
InvertedLogic
Denver, CO
20 JTR
Can you explain in what way the WHP was corrected? I have a hard time believing a stock JL was putting down 270whp.
SCJeeps
TX
2023 JLUR XR, 2023 WL, 1952 Willy’s M38, 2014 WK2
While this looks impressive I have my doubts. Peak HP for the Pentastar is at 6400 rpms, take a look at that dyno run it was cut off at 5500-5600 rpms. Stock numbers for the Jeep 3.6 is 285 hp & 6400 rpms. Looking at the Dyno run the HP curve starts to take a dive after 4800 rpms, I would expect HP to climb all the way to the peak at 6400 rpms. If we assume a 15% drivetrain loss then we would expect to see ~240 hp to the rear wheels.
The torque curve looks like it peaks at the correct location (4400-4600 rpms) however the max numbers seem high. Peak torque should be 260-270.
callerys
2019 JLUR, 1984 CJ7
Something doesn't add up. Note the date on the bottom. 2/14/18. Unless this has been in the works that long ago. Is this graph for a different motor?
