Cali-JeepJL
- Rowan
- Feb 2, 2019
- San Francisco
- Jeep JLUR
I just installed a Poison Spyder rear tire carrier with a Genright license plate & backup camera relocation kit. The first and most obvious problem with this setup is the need to disassemble the camera housing to unplug it before removing the rear tire.
After looking through all the forums I found that this is a problem with any of the rear tire carriers that move the camera if the camera gets mounted in the center.
Took a bit of searching but I’ve found a simple solution. The connector for the camera is a FAKRA connector, and you can buy a 12 inch male to female quick disconnect cable, then just disconnect the camera and plug in the new extension. This gives you a very nice and simple waterproof disconnect inline in the cable, with the factory connectors.
The cable is available here:
https://www.pasternack.com/fakra-pl...mbeMtl6kXknyDHn9eNaalwrIEpFtTXe4aAvQdEALw_wcB
