MOAB Edition JL Club Thread
NTX Black Moab
Tom
DFW, TX
2019 Jeep Moab (Black on Black)
I run my tires at 35 psi and it run so much better.
cram501
Eric
Ashburn, VA
2019 JLUS Mojito! Moab
My babe pickup and after one month!
By the way, My KM2 psi show 43 and stable. But the weather is getting hot. Could this be a problem in summer since max is 50 psi? Should I air down?
I believe the cold PSI for the KM2 is around 36/37 psi. When delivered, mine was around 42/43. I aired down to 36.
Mine also handles better with 34-36psi.
tatarin
Russ
Bloomingdale, IL
2019 MOAB Mojito Sky One-Touch, 2015 Lexus RX350F-sport, 2005 Camry SE
Thoughts about the KM3s in the 295 70 17ss
I didn’t like KM3s too much tire for what my wife and I use our Jeep for.
Boweix
Bowei
Seattle
2019 Jeep Wrangler Moab
SDE
KK, thanks for the advice. I will air it down. BTW, does such high psi impact the MPG?
cram501
Eric
Ashburn, VA
Picked up yesterday. Love the skyroof really like the look of the moab. Steering wheel had a little play on highway took alittle getting use too. Thinking of swamping tires to k02 otherwise no much mods since it's a lease
Check your tire pressure. Mine was up in the 40's when I picked mine up. I brought it down to around 35/36 and the ride was much better. Check the door jamb for the KM2 tire pressure but I believe the suggested pressure is 36.
Drives much better with tire pressure around 35/36.
javelina
WAFB, Arizona
2019 MOAB "Saharacon", 2006 Wrangler TJ, 2018 F-150 RCSB 4x4
I just checked ours. it was around 40.5-41 PSI, (cold). So I took 'em down to 37. the door jam says front and rear should be 37 on ours.
BearJewJonny
Jon
NYC
2018 JlU Sahara
Looks like I’ll be getting a moab soon enough! Any complaints or concerns with anyone’s? Or all positive?
bpdunsta
Chicagoland
2019 JLU Moab
It’s only been 5 weeks, but I love mine. Only “complaint” would be the KM2s. I wish I had read up before purchasing as I would have tried to negotiate some KO2s.
One last complaint: dang weather here in Northern Illinois — I’ve only been able to go topless 2 days so far :(
Lecroj
Jon L
Ridgefield CT
2018 MOAB JLU, 2012 MDX, 2010 Mini
Wish I had gotten the tow package. Otherwise everything is great.
BearJewJonny
Jon
NYC
2018 JlU Sahara
How do you negotiate the tire swap? I feel like there’s no benefits for the dealer
tlmacson
Mac
Detroit, MI
2019 JLU Moab
This is what I was able to negotiate: got dealer to agree b4 closing the deal that they would take off the KM2's and install KO2's that I provided b4 delivery. When I left the dealer with my Moab I had a "trunk" full of KM2's that I will sell asap. I found the KO2's online for $190 ea including freight.
Bricazo
New Jersey
2019 Moab
As other said tow package is a must as it comes with other things like 4 aux switches.. I assumed I had it cause it was fully loaded. Also swapped out my rims and tire and it rides 10 x better!
