Turbo Normalized?
Smooth9883
Patrick
Castle Pines, CO
2019 JLRU & 2018 WK2 Trailhawk
Hi Everyone,
Does anyone know if the 2.0 is turbo normalized? Meaning it produces the same amount of power at sea-level as it does at roughly 8k feet? If not, does anyone know the power drop off per 1k feet with the 2.0? I’m curious if anyone has done any Dyno runs at sea level and then also at altitude.
Thanks
viper88
Nick
IL
Hi Everyone,
Thanks
This is a quote directly from BorgWarner.
"The high-altitude performance of a turbocharged engine is significantly better. Because of the lower air pressure at high altitudes, the power loss of a naturally aspirated engine is considerable. In contrast, the performance of the turbine improves at altitude as a result of the greater pressure difference between the virtually constant pressure upstream of the turbine and the lower ambient pressure at outlet. The lower air density at the compressor inlet is largely equalized. Hence, the engine has barely any power loss."
http://www.turbos.bwauto.com/products/turbochargerAdvantages.aspx
FUHL
Robert
Sandpoint Idaho
cmott426.wixsite.com
2013 F-150 Ecoboost 2018 2-door Rubicon 2013 Range Rover Evoque
CAD Drafter/Engineer
This is a quote directly from BorgWarner. They make the turbo for the 2.0T.
My turbo has "Honeywell" embossed on it.
kingdog23
Phil
CT
2019 JL Bikini Sahara Turbo, 2016 Mini Cooper S Clubman
LED Lighting
That's right. The 2.0 Turbo Wrangler uses a Honeywell (Garrett) unit, and also delivers great performance in high altitudes. It's pretty damn awesome at sea level, too!
MattT69
Matthew
Jeep Wrangler JL Rubicon
This is the main reason I switched from the NA v6 Penastar 🤙 so glad Jeep finally made an engine for high altitude living and playing 🙏
