5JeepsAz
That's precisely it! When your friend bringing you plywood gets stuck upon your chalet, you can tow him up to the ranchuade' so he may unload it near your Gladiator.
I have been keeping track of things to watch out for on the JLs. Here is my list of possible issues, keep in mind I think they effect only a small number of people.
Before I jump into the list let me say that the 3.6 is long proven as most have already told you. Some are concerned it may be under powered but that depends on what you are doing and what you expect. Many feel the tacos are under powered as well, but again this is all relative. As far as the m/t, it is a brand new tranny for the JLs and I don't think it has been around long enough to comment on the reliability/longevity. It is made be Aisin, and they have been making solid transmissions for Jeep for a very long time. It is said to have a very light clutch and short car like throws. Unfortunately it greatly decreasing the tow rating and can only be matted to the 3.6L. Still I will be rowing my own in my JT.
Ok here is my list of issues, if anyone else has more to add please let me know.
Steering - seems to be the biggest concern and the solutions vary from software update, to new steering box, to new front end components, adjust tire pressure, to just plain its a SFA its going to be bumpy and take slight more effort to steer, Jeep thing.
HVAC - unless corrected for the JT, some have complained the HVAC dumps unfiltered air into the cabin, which can be hot in summer or cold in the winter. Supposedly only for brief moments and done on purpose by Jeep engineers to prevent CO2 cabin build up. You can decided if that answer holds water. Although it sounds annoying its not a deal breaker for me.
Speaker rattler - a few have complained that the front drivers speaker harness is loose and causes distortion. Easy fix to secure.
Frame Welds - some JL had issues with frame welds and there was a small recall, seems to be fixed and an isolated incident. You are a Toyota guy so you should know about frame weld issues.
Wind noise - some have complained about the hard top causing the buffeting, as far as I can tell, it just means the weather strips on the freedom panels are not sitting quiet right. They can be played with to fix the issue but getting it right may take some trial and error. Also if people are complain about noise with a soft top, yeah Jeep thing, still awesome.
Fuses - when you take delivery push fuses in to ensure they are fully seated, otherwise electrical issues can happen. There have been some isolated non fuse issues with the electrical as well. I don't have much info on those.
Then you have people concerns about issues they think will happen but haven't yet. example ESS/Starter problems, FAD front axle disconnect, etc. time will tell if these are valid concerns. I am not to worried.
Hope that helps.
I'd put my 2 Toyotas up against ANY JEEP as far as reliability. My 2015 4Runner is extremely comfortable and is really tough. 135,000 miles and finally just replaced the brakes. Other than that just maintenance. My 94 pickup isn't very comfortable but is bomb-proof. I think I replaced a starter and exhaust and have over 270,000 miles on it. Check out the TopGear episodes on youtube where they try and kill an old Hilux parts 1,2 and 3. They buried in the ocean, dropped a camper on it. hit it with a wrecking ball, lit it on fire, it fell 240' on a demolished building, They dragged it out of each situation and it started up and they could drive it. PRETTY KICK ASS IF YOU ASK ME
Also, check this out about a 4Runner that had a huge tree crush it. and keeps on going.
I've been very happy with them.
This shouldn't be a pissing match....both brands make kickass trucks and I can't wait to add a Jeep Gladiator to my garage.
My 2010 Grand Cherokee was actually a POS in comparison- poor performance, a few issues before 100k, but after my 05 4Runner saved me after a head-on collision I was in a pinch and the only new decent SUV I could get for the price was the GC
I routinely give and get thumbs up from Wrangler drivers all over the country when I'm in my Toyotas.
Scratch frame welds. JT and JL are completely different framesvery nice synopsis for others that don't know. thanks!
Are they both sourced from Tower?Scratch frame welds. JT and JL are completely different frames
Forgot about a few additional things to add. Any other forum members have anything else? Again this is not bashing Jeep as I am for sure getting one myself, this is just to help me and others know what to look out for when taking delivery and to best anticipate any issues early on.
Defrost issues - some JL owners say that the defrost only clears the center of the windshield and leaves the edges frosted over in the winter. The fix has been to plug some of the center defrost holes, which forces air to the outside holes. They have used everything from heat resistant plastic plugs to metal bars. While I think Jeep engineers should really address this issue, most of the fixes I have seen are inexpensive, easy, and are not noticeable as many blend right into the dash.
Advanced Safety group - some say that having the sensors behind the review mirror obstructs some of their view. I'm 5'10'' and don't expect it to be a problem, however I plan on sitting/driving a JL with the advanced safety group before I order it.
Tell me where I was bashing Jeep. All I said was that my 2010 Grand Cherokee in comparison to my two Toyotas was a POS. I had more repairs needed on that vehicle in less than 100,000 miles than both of my Toyotas that have logged over 300,000 miles combined. This was my personal experience with one vehicle. I also said I cannot wait to add a Gladiator to my garage.Dude-
You come on here bashing Jeep and singing the Toyota fan boy song.. Really?
There are problems with any manufacturer...for instance how many taco frames had to be replaced because Toyota used inferior metal?? I don’t know the answer but it was thousands if not tens of thousands... there are several other issues as well.
As for comparing your taco to a Hilux you must be smoking something. The Hilux shares virtually no parts with the Taco...
I respect all opinions but you should be mindful of where you are.....if you want to stir the pot just go somewhere else...
I am also a lifelong toyota user, however, I would love to switch to jeeps specifically the new fully loaded Gladiator Rubicon. I have always preferred the jeeps looks but the Toyotas reliability(my experience only, maybe if I had jeeps the experience would be similar, hence the post) I no longer Offroad as much as my youth but still enjoy it as often as I can. I have a 1999 land cruiser with some additions: emu suspension package, arb bumper with winch. I pay cash and usually by used. For tax purposes I can now by new 4x4's. Because I believe the loaded gladiator makes the IRS's 6000gvwr limit for deduction I am curious if I can expect the same 200-300kmph lifetime out of it. My two current Toyotas, 1999 Tacoma and a 1999 landcruiser each have over 250 and other than minor repairs each Are still road worthy. I measure minor repairs by cost. Combined vehicle repairs/maintenance costs me less than$45/month the ten plus years I have owned them. Biggest repairs and/or maintenance where timing belts and radiator for tacoma and front ball joints on the landcruiser. Lastly I am fortunate enough to have a mechanic to do all my repairs. But this doesn't mean I am not reliability conscious... So what's the consensus? Can I expect similar results form the Gladiator? Thanks.
