Airing down difference
LLRubylady
Lisa
NY
was an ‘18 Rubicon Mojito! now a boring Mazda
are e load tires harder to air down for sand driving or doesn’t it make a difference?
ECHO
Craig
Pennsylvania
2-Door JL Rubicon - Black
Retired Air Force - Currently in my Dream Job
It doesn't matter , the sidewalls are stiffer on an E rated -vs- C or D .. process is the same
Andy2434
Andy
Las Vegas/San Francisco
'19 Billet JLUR, ‘20 Mustang GT/Prem/6MT/PP1
Retired/Leisure
Simply air them down as you normally would.
LLRubylady
Lisa
NY
Thank you. Good to know. I’ve only done it once years ago.
Waiting for it to warm up to test out my rubi in sand
Columbus104
Kurtis
Columbus, Ohio
2018 Wrangler Moab (white)
One thing to note about sand. While normally people go down to around 20 psi for offroading on rocks, sand you want to go even lower. I recommend 10 psi or even lower.
LLRubylady
Lisa
NY
From what I’ve read it’s better to have an 8.5 wide wheel for stock ko2 33s than a 9 inch to keep the bead on. I sold my stock wheels.
jarvis
PA
2019 JLUR Manual, 12 Toyota Tundra Rock Warrior
I will have 35x12.5 on my stock Rubi wheels, will airing down be an issue with this setup? Previously I aired down to ~18 on my Tundra for driving Carova Beach in OBX and it did fine.
TxJeepers
2022 JLUR XR
20? Closer to 15 or less where I'm at. Same would be good for deep sand. If you don't run beadlocks, be careful down around 10 or less.
TxJeepers
2022 JLUR XR
What kind of tire? That can play into it as well. ATs generally do better than MTs in sand. Regardless, taking your 35x12.50's down to 15-20 will be fine. Just don't do any HMB driving!
Andy2434
Andy
Retired/Leisure
Having a good set of traction boards and a shovel is a good idea, as well.
LLRubylady
Lisa
NY
jarvis
PA
Nitto Ridge Grapplers, I will be driving mostly road conditions with a splash of trail and sand, no need for MTs even if they look better, and please forgive me, what is HMB?
IronScott
NW Arkansas
2019 JLU Sahara, 1992 Jeep YJ, 2002 Chevy Silverado
Hold my beer :LOL:
Wraif
New Jersey
19 2-door manual Rubicon, 09 JKU
With the E load tires, you might have to air down a little more, the sidewalls are a bit stiffer. Better puncture resistance. Once the loosen up a bit they could work well. Go to about 13-15 psi with those tires. I run Goodyear MTR’s and I go to 12 psi without headlocks. Good luck and have fun.
