AFfiredawg
Where did mopar says this...I haven't seen it anywhere except through hearsay from you...So is it not enough that Mopar says it is OK to tow but and then they say do not use a bumper connected via the frame-plate? Not trying to be an ass however it is disturbing to see folks blatently ignore the safety advice of the OEM manufacture of the vehicle and taking the advice of a small after market parts company... What is wrong with that picture.
When or if an accident happens that small company will be gone and Mopar is going to say we told you so... The insurance company could also potentially decline coverage if the OEM manufactures advice was ignored.
Look towing a 5000lb car can have life changing impacts if not properly done and or safety recommendations ignored...
Again, what safety advice/reccomendations? You have yet to show where they put in writing that the baseplates are ok but the Bumpers aren't...You probably will never get them to tell you it is ok...They will not assume that liability.
Mopar will say that if you are in any kind of accident and it was the fault of any aftermarket part....
Insurance could decline coverage period, if you altered the original vehicle in a way that caused the accident...it doesn't matter if it was an aftermarket bumper or an aftermarket baseplate...We are all taking a chance no matter how we connect...realistically, as long as you follow the guidance in the manual(which doesn't address how the connections are made) and the guidance of the aftermarket part manufacturers (who say whether or not you can tow with their devices) then your insurance will likely cover you. Then they will go after the company who's part failed...if it failed in a manner of use they said was acceptable.
