Debadged my Sport and Dipped the Trail Rated Badge
smithrd65
San Antonio
2018 Jeep Wrangler Rubicon Unlimited JL. BMW Z4 35is, Tesla Model X90D, Chevy 2500 LTZ
Question? WHATS THE PURPOSE OF DEBADGING?
raqball
Washington
2018 JKUR
Debadged mine today and it was a PIA.... Mine must have had some ant-debadge glue applied at the factory :P..
Took about 3 hours total with a blow dryer and goo-gone.. The Unlimited Sport stickers were easy and quick but the JEEP letters on the sides? Nope!
Heated each letter up one at a time and removed after heating. This still left a very, very, very thick amount of tape behind. That tape was suck on and then stuck on some more. After about 2 1/2 hours I had them all removed only to find the driver side still had the JEEP outline showing when viewed at a certain angle in the sun. Almost like it had baked into the paint... SMH! Grabbed some rubbing compound then buffed it out...
Was it worth 3 hours? NO! But once I started I was determined to finish it up..
Kenny
Ken
2018 jl sports, 2015 JK Unlimited, 2013 JK @ Dr
Village Idiot
I always figured that people mask and spray - not remove dip and reinstall.
On the JK there was nothing but I've heard there is an antenna hole under the trail rated badge on the JL. I have a powder coated badge I'd like to put on but not if I am going to run into a real issue. has anyone removed the JL trail rated badge?
If not - plasti-dip here I come
Kenny
Ken
Village Idiot
I wish I would have seen and paid attention to this - I have the last layer to go after three hours
raqball
Washington
2018 JKUR
You will probably have some letter ghosting too like I did... Use some rubbing compound to get rid of it if you do...
Kenny
Ken
Village Idiot
Off to Pep Boys - thanks
raqball
Washington
2018 JKUR
Kenny
Ken
Village Idiot
Jrauck
Houston
2006 Jeep Wrangler TJ
Just debadged my JLUR. I did it within 2 weeks of getting it so there was very slight ghosting (you had to actually look for it). I plan on using a rubbing compound to get the ghosting off.
Since I peeled the stickers off pretty soon after getting my jeep and did it after sitting in the heat all day, I didn't even need to use a heat gun. I just peeled them all off. There was residue left, but I used 3M Adhesion Remover (meant for paint) and it came off without a problem. Just keep in mind what you take the residue/stickers off with as you can scratch your paint. One option if you have a drill is to use a decal remover wheel. Example here: https://www.amazon.com/Whizzy-Wheel-Decal-Remover-Adapter/dp/B00FJF0O2K/ref=sr_1_2?ie=UTF8&qid=1531431853&sr=8-2&keywords=sticker+wheel
JxRYE
1986 CJ-7 Renegade, 2019 Jeep Wrangler MOAB
I removed the Jeep badges from the side of my JLU and plasti-dipped the Trail Rated badge today. Thought some of you may want to see what it looks like without them!
close up picture of the plastidiped trail rated badge? debating doing the same.
Kenny
Ken
Village Idiot
Ditto
