I added LED lights to my steps. So RSE sells a kit for $70. Being cheap I decided to give this a go myself first.
So I bought these lights for $7.99.
https://www.amazon.com/gp/product/B01GJ3O0J8/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Then I went and got 2 new connectors like in the pic for $4.09 as that was easy to match the LEDs connector then the RSE connector.
Great chatting. Good luck on your install.Can you help me figure out what other pieces you needed for this install. I see the LED strip light. But it's not exactly clear what else you purchased? What do you use to attach the led strip to the step up bar? Is there a plug on the bar that receives something or do you wire it?
Those wheels are looking good! Even if you can’t get a Sting Gray powder coat, you should be able to find a coat that will match the wheels.FINALLY. Wow it took me forever to decide what tires I wanted. After much agonizing I decided on the Toyo. Here they are mounted up. I still need to order up lug nuts but now I have a bigger issue. We got relocated to KY so the Jeep is on its way there and these are in the garage in SoCal. Not sure when they will get mounted.
Also working with LOD we decided to go with their full set up. Front, rear and tire carrier. Waiting for it to arrive in raw metal and then we are going to powder coat it Sting Gray if I can get a match from the shop. If I can’t get a match, well then no idea.
Very excited to break free of CA. Born and raised here. It is time for a new adventure and we are really excited. The LOD’s really fit the bill. Bumpers were tough. I had a lot of things I wanted.Excited to see how she looks when you're done! Hopefully Kentucky is better than CA (heck I'm sure anything is ha!)
Post some pictures once you get those LOD items! Their back bumper is still on my radar down the line but not for a while!
Working on powder right now. Gonna try to match sting gray. If that works and then the wheels look bad we will powder the wheels. Next will be to match the wheels and see if that works for the bumpers and pull off sting gray and the argent from the wheels as the two colors. Last will be just go a semi gloss or satin black non texture for the bumpers and be like everyone else with black bumpers.Those wheels are looking good! Even if you can’t get a Sting Gray powder coat, you should be able to find a coat that will match the wheels.
Sure will when all mounted. Still in boxes. Going to powder coat this week and depending on schedule not sure when I can get them mounted.It looks so good!
What are your thoughts on the LOD rear bumper and tire carrier?
That's what we'll end up with one day, just not right now
Also, would you be able to post some more photos of the rear tire carrier? I'm curious to see how everything looks and sits. Additionally, are the rear sensors working correctly when you relocated them as well? The ones on our current bumper go off all the time because our spare tire is too big right now :p Just curious how it works on theirs.
