Hey I don’t run a Tazer but have a trailcal that displays constant coltage (mirrors ecm).I did not even think any fan messages were displayed in the EVIC so can’t even make a wild guess what that might be
I’m one that really appreciate all you’ve done! That’s a lot of work that you put in to get all of this info doing it with and without the Tazer. With all that has been said about the Tazer and that it may be causing issues, it looks to me like at least with 11.06 firmware and the setting you’ve used that it is not causing the battery issues that some may have thought. Who knows.Here is my last day of testing voltages
Day 7
12.58 Main
12.58 N1
12.59 N2
12.61 ESS
13.2 EVIC
Was going pretty well after taking voltages but then I started the Jeep and the Uconnect radio seemed to be back lit so I let it sit while running and it rebooted twice before going to a normal screen, cannot say this is because of the Tazer as it’s done this at least a couple times since owning and I don’t have the 8.4 so it’s not OTA updates
After getting to where I was going I shut the Jeep down and let it sit till all dark then restarted and all seems normal, like I said it’s happened before but not for quite awhile
I have crunched the first set of numbers for the 7 days with it married but not plugged in and will try to get the rest done this evening but just glancing at the numbers it does not seem the Tazer I am running is causing any issues, my daily voltages ran in the 12.55-12.65 on both the main and ESS and EVIC displayed voltages were in the 13.0-13.3 range with an occasional spike to 13.8 but this happened with it plugged and and not plugged in and was only after it had been sitting all night or all day.
The only vehicle settings I used were tire size, tpms limits and fog light drop and the only live setting was disable ESS and when I had it disabled I tested it every way possible and had no issues what so ever so this evening I will post all my voltages to show you what I got.
This a.m I unmarried the Tazer and ran a few errands and after a few hours I did a quick check of voltage and all were the same with the Tazer removed and unmarried, Main was 12.60 ESS was 12.58 and EVIC was 13.4 so I married the Tazer back and put my battery on my charge and will spend the next month just letting it ride and see if I get and goofy readings or behavior
I totally understand! Since these things are so new it’s going to take everyone some time before we get everything figured.The day my battery drained - also coincided with he first successful UCONNECT health report (prior just said failed). I think UNCONNECT updates have something to do with the battery, not the Tazer. the unfortunate part is the proximity of the tazer install to dead battery didn't make me feel super confident.
