xpsruler
I hadn't seen anyone use this switch system yet on here so I thought I'd share an additional option for auxiliary switches.
I came across a company called S-Tech as they are out of Colorado where I live that make a set of switches that can be used for lights and install cleanly in the dashboard.
...I know the wires look a bit messy but I previously set up multiple other lights as well as a winch before installing this.
You can get it in either a four switch or six switch setup and its a lot more affirdable than the Mopar option. It additionally requires no flashing of the vehicle and if you use the code jllife20 you get 20% off .
