Uhdinator
A couple of of things with lifts and bigger tires...It depends on the model of wrangler and how you use it.
A rubicon with 4:10 axle gears and a lower range transfer case will handle 35's without a problem without being under powered or drastic loss of MPG. Rubicon has more fender clearance and needs less lift than the rest. 35's will fit stock especially if all you do is commuting.
A Sport has 3:45 gears, and a higher geared transfer case. 35's or larger are going to make it a dog with MPG and stress the axles a bit more if you do hard core trail wheeling.
A Sport S could have 3:73 gears and be in between the 2 above.
My 2.0L Sport seems to have enough power that it doesn't feel powerless with 33x12's and I get 26 MPG and not broke in yet. It looks much better, but if I wanted bigger tires than 33's I would have gone with a Rubicon for the gearing and stronger axles and not lift it and mess with the ride.
You need better and longer shocks with a lift also. High lifts have more parts required to adjust alignment, relocate brackets etc, extend brake lines... more involved the higher you go...
For hard wheeling there are some disadvantages to being to high like with steep inclines etc....or highway off ramps.
